ElanScan Interface
Re: ElanScan Interface
Postby JusNoGood » Fri 11.05.2018, 14:01
Hi Geoff,
Thanks very much for the cable. Received it some time ago but just been too busy on the car!
I've read the wiki but the link on there seems to link to a Win98/2k and no mention of XP (looking at the readme and also trying to install using the VCP folder and I get no drivers present). Do you have a link to the XP drivers please?
Justin
JusNoGood
Postby Fredjohn » Fri 11.05.2018, 15:58
Justin
I've used Elanscan on XP, Vista and 10 with no driver problem (other than the one behind the wheel).
Load Elanscan and just try a driver update in the control panel/programmes area.
Postby JusNoGood » Fri 11.05.2018, 16:12
Fredjohn wrote:Justin
Unfortunately it tries to install the driver, doesn't find it, and then there is an error entry in the device manager. If I click on upgrade driver it doesn't find it, even if I point it to the VC file.
JusNoGood
Postby Dazzle » Thu 28.06.2018, 00:34
Hi Geoff,
Do you have any interface cables available as I would like to purchase one, thanks.
Scratch that decided to have a go and make one up :-?
Dazzle
Postby GeoffSmith » Sat 22.09.2018, 14:37
A few people asked while I was in Spain…
I now have a couple more USB versions built up if anyone is still after one. Be warned, I'm almost out of pcbs and ALDL plugs, so it's pretty much the end of the road as re-stocking/buying singly is prohibitively expensive.
Postby a5gcd » Sat 29.09.2018, 20:00
Hi Geoff
This doesn't work for me either.
Can you tell me how to get the drivers for your original USB interface to use it with Windows 10. I can get the PC to recognise the device but I cant update the drivers.
Geoff D]
a5gcd
Postby peteric » Mon 01.10.2018, 13:54
Hi Geoff
I would like a cable please.
Peter
peteric
Postby scubasteve » Tue 09.10.2018, 11:34
GeoffSmith wrote:A few people asked while I was in Spain…
Hi, I'm new to forum and new to owning an m100. bought it with a problem though 'cos I like a challenge.
car won't run over 3000rpm and I have no eml on dash (doesn't illuminate when ignition turned on - suspect bulb removed to get it through MOT)
so I was considering the aldl interface you do (if you still have one) to investigate the issue. thanks.
If I can't fix it - - it don't get fixed!!!
scubasteve
Postby clemo » Tue 09.10.2018, 20:32
As a Mac user i and subject to much abuse from Pinky. This also gives him more "told you that they are crap" ammo.
That said i could probably buy some kak old phone to get me in the LEC bluetooth Elanscan world .
So as per usual i would like to acquire said item fashionably late ( or did you have an plug in thing for the very old MK1 version that timmo only returned to me once his ZX81 computer died !.)
Ta .
clemo
Postby GeoffSmith » Sat 20.04.2019, 20:10
Right, I've cracked it… but only after testing a couple of new interfaces on the bench (which worked fine) but then refused to work on the car.
The problem is not W7 Home but the installed FTDI VCP driver:
2.12.12 is good
2.12.24 SENDS DATA BUT DOES NOT RECEIVE DATA
2.12.28 is good
Postby niall » Mon 22.04.2019, 22:40
Geoff,
Could you please point me in the direction of a link to one of those good versions please.
niall
Postby GeoffSmith » Tue 23.04.2019, 08:02
The latest drivers are on the FTDI website:
https://www.ftdichip.com/Drivers/VCP.htm
Postby dave excell » Wed 08.05.2019, 05:38
Hi
I need one asap please. Payment details please. I have a fault I need to clear/fix.
Dave Excell
dave excell
Postby Roger D » Sun 27.10.2019, 13:44
Geoff,
I’ve just bought a lovely Silk Red SE (1992) which is running a little rough and would like to purchase a Elanscan cable to run off my Windows 10 PC.
Hopefully they are still available.
Can to send me the payment details so I can sort my new toy out?
Roger
Black K Series Elise S2
Claret Excel SA (now sold)
Silk Red Elan SE
Roger D
Postby johanvanboven » Thu 21.11.2019, 00:24
Good evening Geoff,
Is it still possible to buy an interface cable for the Elan Scan? If so, i would be interested.
If not, I will make it myself, as I ever did for my Esprit 1993. Are there any scheme's available?
Thx a lot for any help available, Johan
johanvanboven
Postby texas2201 » Tue 26.11.2019, 14:31
Hi do you have any USB cables left?
Postby GeoffSmith » Sun 15.12.2019, 23:07
Apologies for the silence but prostate and Spain have taken my mind off this. I ran out of circuit boards last year but there weren't many requests so it's been on the back burner. I've checked through e-mails and PMs and the good news is there appears to be sufficient interest to produce some more. I have ordered a batch of 16 pcbs and I should have some available before the end of the year but this will probably be the end of production. The weak Pound has pushed up the cost, particularly of the pcbs and the FTDI device, by over £5 so price incl. P&P is now £60.
Feel free to add your name to the list and send me an e-mail (elanscaninterfaces[ A T ]gmail[ D O T ]com)..
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
Postby Roger D » Sat 21.12.2019, 14:23
Geoff,
Spain sounds nice not so sure about the other, hope you on the right side of it now.
Please put me on the new list. Can’t seem to edit your list? I will send an email.
Roger
Silk Red Elan SE
Roger D
Postby Fredjohn » Sat 21.12.2019, 16:10
Roger: you cant' edit someone else's post. However, you can copy it and then paste it into your own new post(reply). Then you can add your name, as I have for you below:
Feel free to add your name to the list and send me (Geof) an e-mail (elanscaninterfaces[ A T ]gmail[ D O T ]com)..
1. Roger D
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
Postby johanvanboven » Sat 21.12.2019, 22:08
Let's see if it works,
1. Roger D
2. Johanvanboven
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
johanvanboven
Return to ElanScan
