Can you please comment on the scan?
Postby sinannasirli » Tue 06.09.2016, 22:07
Dear All, I made my first scan.. please find results attached. Can someone please comment if there is anything unusual?
Especially my main problem I do not have boost. The maximum boost I caould achieve is .25 bar.
I did a wastegate wiggle but it did not help(maybe should have spent more time). The car is 35.000 miles. CAt is cancelled and tht exhaust pipe looks like quite narrow (41 mm), if any of above makes any difference...
Thank you ın advance!!
Sinan
1996 Lotus Elan Turbo S2, Empire Green, No 766
1995 Maserati Ghibli 2.0
2000 Porsche 996 Carrera 4
1969 Chevy K10 Suburban 4x4 i6 250ci
1970 Opel GT
1953 Willys CJ-3B Jeep
1958 BMW R26 Motorcycle
sinannasirli
Re: Can you please comment on the scan?
Postby sinannasirli » Tue 06.09.2016, 23:35
Boost/rpm for my car
And this is wastegate cycle vs. boost, blue one my car, black data taken from wayne sample test..
Would that mean a leak etc? What shall i look for? Thanks
1970 Opel GT
sinannasirli
Postby sinannasirli » Fri 30.09.2016, 22:36
Hi.. Still waiting if anyone can...
1970 Opel GT
sinannasirli
Postby Giniw » Fri 30.09.2016, 23:44
Well, I think your idling manifold pressure is a bit high.
As far as I know, it should be around 0.30-0.31 bar. Yours seems to be more around 0.35-0.36 bar, so there might be a little leak to fix.
I don't know whether that could explain such a low boost, though.
PS: I think you should ask someone to move your post in the "Turbos, Boost, and Intakes" part of the forum (viewforum.php?f=31)
Giniw
Postby GeoffSmith » Mon 03.10.2016, 09:43
Definitely looks like a leak. Remove the corrugated pipe from the air filter and blow into it to see if it will hold pressure. You may be able to hear a leak - favourite places are the small connections at the manifold and the vacuum reservoir tucked under the wheel arch liner. Then go and look in the mirror and admire your new goatie beard.
Postby Giniw » Wed 05.10.2016, 10:40
(lol :lol: )
Giniw
Postby sinannasirli » Fri 21.10.2016, 14:01
Thank you for the advice..
I was waiting to reply until I do this, but still could not find time to do due to travels.. As soon as I do this will share the results
1970 Opel GT
sinannasirli
Postby Giniw » Fri 21.10.2016, 17:48
(Do you mean you will share a photo of your goatie beard? :D)
Giniw
Postby GeoffSmith » Fri 21.10.2016, 18:10
Postby sinannasirli » Mon 14.09.2020, 12:37
I was going trough some posts and noticed that I never closed this thread and shared the end results..
The PO had put a smaller diameter exhaust piping ( cheap repair) that was the issue.. The poor engine could not breathe, that was why there was no boost..
So if anyone there, please check exhaust piping first..
Also sorry that I have never shared picture of my goatie beard.. :D
1970 Opel GT
sinannasirli
Return to ElanScan
