Connector plugs for Gemini Aquila alarm
Postby KenS » Sun 10.06.2018, 19:15
Hi, does anyone know the brand and type of connectors used on the Gemini Aquila 5160T alarm unit (used on the S2)? I have a Toad Ai606 ready to replace the original Gemini, was thinking that it would be easier if I could source the correct connector half to terminate the Toads wiring, making it a quick swapover for most of the connections. They look similar to Molex Micro-fit connectors, but those do not come in 3 row style (looks like they are split as a 3x3 and a 3x5 pin matrix). Any leads appreciated !
S2 NMY #285
KenS
Re: Connector plugs for Gemini Aquila alarm
Postby Saltire » Sun 10.06.2018, 20:02
Been there, tried to do that, got the T-shirt :?
I searched high and low without success. Eventually I labelled the wires going into the Aquila, cut the connectors off and used two new multiway connectors with new terminals soldered onto the wires. Somewhere - if I can find it - I have a conversion chart between the old Aquila wiring colours and the new Toad alarm.
It’s not too hard, but it is a bit of a faff
Postby KenS » Mon 11.06.2018, 21:23
Starting to think that changing the alarm is a job to put off for the winter when I can pull the dashboard in slow time to make access easier. Meanwhile I try to map out my exact connections, especially the black ones. Do you know if the Gemini ultrasonic sensors can be re-used on the Toad or do they need stripping out and swapped for ones supplied with the Toad?
S2 NMY #285
KenS
Postby Saltire » Mon 11.06.2018, 21:51
No, Ken, the Toad comes with its own ultrasonics which must be used. I also fitted a microwave and tilt sensors as options. Contrary to what the Toad instructions say, I fitted the ultrasonic sensors in the OEM locations. It’s a bit of a faff, because you have to remove the windscreen header rail and enlarge the holes slightly, but it can be done. I took the opportunity to add a dash cam power supply, a digital radio aerial and connectors for some extra LED lighting in the foot wells while I was up there.
You’ve reminded me to look out my notes of the connections - may save you a pile of time.
Postby Saltire » Tue 12.06.2018, 21:05
I’ve found my connection schematic, but it needs a couple of changes. Once they’re done - a day or so - I’ll PM it across to you. For obvious reasons, I don’t like to put details about the alarm systems on the open forums.
Postby KenS » Wed 13.06.2018, 21:53
Thanks Jonathan, any info will certainly be useful. One of those jobs that takes some courage to start !
S2 NMY #285
KenS
Postby Saltire » Thu 14.06.2018, 11:14
Hi Ken, you have an email with lots of details in it. Let me know if anything's not clear.
Postby KenS » Thu 14.06.2018, 20:29
Email received, many thanks Jonathan, a lot of useful info which makes the job a lot less daunting.
S2 NMY #285
KenS
