Measuring fuse voltage to determine circuit current
Postby GeoffSmith » Thu 29.03.2018, 20:40
Very useful diagnostic tool on this website:
https://www.powerprobe.com/fuse-voltage-drop-charts/
Re: Measuring fuse voltage to determine circuit current
Postby lotusflasherman » Thu 29.03.2018, 22:22
You've got me on that one Geoff ... :smt017
not sure how you get on the fuse blades to read in millivolts and if a 30 amp maxi fuse is 0.00195 Ω, according to the chart, contact resistance of the probes is likely to be significant..
I just pull the fuse out and use the milliamp scale on my multimeter.... seems easier .. :-D
Postby GeoffSmith » Thu 29.03.2018, 23:12
No need to get to the blades Phil. Just plug your voltmeter into the convenient connections on the back of the plug.
Postby Simon_P » Fri 30.03.2018, 00:24
Useful - does it work in practice Geoff?
Phil, I presume it is simple V=I.R so using voltage drop across the fuse of known resistance to give Amps.
Probably most useful for measuring loads on the larger fuses where putting an ammeter in the circuit is less practical.
Postby Rambo » Fri 30.03.2018, 09:51
GeoffSmith wrote:No need to get to the blades Phil. Just plug your voltmeter into the convenient connections on the back of the plug.
Well, i never knew that. You learn something new every day ;-)
Postby lotusflasherman » Fri 30.03.2018, 14:46
Song from Porgy and Bess -" It ain't necessarily so" ... sums it up.
I know what I'd find fitted when if I went to use that method.. :lol:
Top one has visual 'fuse blown' , lower one needs electrical test on contacts - or withdraw for visual.
Postby lotusflasherman » Fri 30.03.2018, 15:25
Simon_P wrote:Useful - does it work in practice Geoff?
Yes, it's Herr Ohm's clever idea... fuse element has a certain resistance and the heating effect is square of the current x R so 10 amps give 100R watts, 11 amps gives 121R watts.
Not too tricky to make a fuse that carries 10 amps but melts at 11 amps by changing it's ability to get the heat away.
Even the cheap multi-meter that lives in my little toolbag in the boot reads up to 10A on a dedicated terminal, most of them do...
Anything more and I use a cheap clampmeter that goes round the wire, that will read to 600A.
Postby johanvanboven » Fri 30.03.2018, 15:34
If you're not so good in calculating, buy this: https://store.snapon.com/Specialty-Circ ... 69765.aspx
Choose the type of fuse and the tool does the rest. Very easy to quickly detect leakage current.
johanvanboven
Postby peteoddcar » Thu 26.04.2018, 20:41
I have been using one of these for a while it works ok, to determine the level of current, before connection of Fluke multimeter. The current measurement seems to correlate with the Fluke.
https://rover.ebay.com/rover/0/0/0?mpre ... 0439841044
other sins :- 72 Dolomite Road Rally Car.'73 Mini 1275 Road Rally Car.
peteoddcar
Postby Tuga2112 » Thu 08.11.2018, 13:23
i came across this a few years ago when hunting a parasitic drain (cant remember which car)
as far as im aware this technique has limited uses in the elan. (with exception for cars with alarm/imobiliser systems and faults in related circuitry)
it seems to be mroe common in modern cars
https://www.youtube.com/watch?v=T6rDTtxaeJ4
[youtube]https://www.youtube.com/watch?v=T6rDTtxaeJ4[/youtube]
1991 elan se
1991 elan se project
91 MR2 Turbo (import) project
94 Celica GT4 (Import)
94 4Runner
98 Celica SR
Postby sideways » Thu 08.11.2018, 19:56
I'll stick with my Avometer 8sx for this sort of thing, easy to use and you will never lose or misplace it. :D
sideways at speed
Delta BC Canada
sideways
