Central Locking Problem
Postby Graaf » Wed 20.05.2020, 19:12
I have just put the door cards back on and now have a problem with the central locking.
When I try to lock the doors the passenger button goes down but a few seconds later unlocks. It was fine when I tool the door cards off.
Any suggestions??
Graaf
Re: Central Locking Problem
Postby Tuga2112 » Wed 20.05.2020, 20:07
There's a sensor at the door to recognise if the doorr is open when you lock the doors.
If the sensor tells the computer the door is open. Them the computer will unlock the doors automagically.
I suspect you may have disturbed the sensor or wiring.
1991 elan se
1991 elan se project
91 MR2 Turbo (import) project
94 Celica GT4 (Import)
94 4Runner
98 Celica SR
Postby RonR » Thu 21.05.2020, 21:05
This could also be due to the adjustment on the internal lock/unlock button.
When you tighten the screw under the orange clip there's a slot for height adjustment.
If it's adjusted too low and you attempt to lock the door it won't quite operate the switch in the lock to signal the Central Locking Module that it's locked.
Postby Tuga2112 » Thu 21.05.2020, 23:46
RonR wrote:This could also be due to the adjustment on the internal lock/unlock button.
That actually sounds more likely than what I suggested
1991 elan se
94 4Runner
98 Celica SR
Postby Graaf » Fri 22.05.2020, 09:54
Thanks guys.
RonR - I didn’t know about this so that’s my afternoon sorted!
Thanks again
Graaf
Postby Graaf » Fri 22.05.2020, 14:47
All sorted now, thanks chaps
Graaf
