Dasboard/Instrument Lights - replacement bulbs?
Re: Dasboard/Instrument Lights - replacement bulbs?
Postby Brit-Car-Nut » Sat 08.03.2014, 03:52
TrevorB wrote:I've investigated the problem and found a loose connection on the oil gauge lamp holder whilst refitting the lamp flickered and then
nothing, heard a click and now all the instrument lights have gone out. Looking at fuse diagrams on wiki I cannot identify a specific
fuse that covers the instrument lights. Fuse 3 in Box C states RHD CDL, what is that for :?: Or is there another problem I need to
investigate :?:
There are no other problems and car is otherwise working fine.
Thanks for your help, as always.
:cheers:
Trevor: The instrument lights are controlled by the panel rheostat and a rheostat module. The circuit gets fed from the sidelamp circuit and there are no fuses involved after fuse A7 (5A) and if that popped, the RH sidelights and tail lights would not work. The LH sidelights and tail lights get fed by fuse A6 (5A). If you have both tail lights and the sidelights both work, I would suspect that you heard the module popping. It is part # A100M6059F which is on SALE for £7.08. The parts book says it is a GREEN module.
Best to look at Sheet 9 and Sheet 22 in the Electrical Manual
Postby TrevorB » Sat 08.03.2014, 17:44
Brit-Car-Nut wrote:Trevor: The instrument lights are controlled by the panel rheostat and a rheostat module. The circuit gets fed from the sidelamp circuit and there are no fuses involved after fuse A7 (5A) and if that popped, the RH sidelights and tail lights would not work. The LH sidelights and tail lights get fed by fuse A6 (5A). If you have both tail lights and the sidelights both work, I would suspect that you heard the module popping. It is part # A100M6059F which is on SALE for £7.08. The parts book says it is a GREEN module.
Hi John, Thanks for the information. I have had a look to see if I can identify the rheostat module but not knowing exactly what I'm looking
for and location cannot see anything that may help. Access to see anything is difficult. Do I need to remove panels, I did manage to
release lower steering wheel panel but could not see anything there. (Probably because I'm in completely wrong place). Presumably the module
is a plug in replacement module once I get to it? If there are any photo's of location and what I'm exactly looking for would be appreciated.
I am assuming this is the problem as side lights and tail lights are working fine.
Apologies for very basic requests but I'm an extreme novice when it comes to this type thing but am willing to try.
HiSpec front brakes
PNM rear brakes
Aluminium radiator
Closed Loop conversion
Kilimanjaro chip
Wannabe Princess
Postby Brit-Car-Nut » Sat 08.03.2014, 18:02
Trevor: Here is a diagram of relay locations:
You are looking for a GREEN relay :
Postby Jeemy » Sat 08.03.2014, 19:23
On UK Cars, the block is indeed under the dash to the right of the steering wheel. Easy to find.
Some slots are empty, on mine.
T: 0800 084 3084
M: 07391 295 146
Jeemy
Postby TrevorB » Sun 09.03.2014, 13:04
Jeemy wrote:On UK Cars, the block is indeed under the dash to the right of the steering wheel. Easy to find.
Hooray found it, now if there is any requirement for 65 year old contortionist I'm your man :lol:
Ordered new one from SJS so I will join local yoga class to prepare for next job :D
Thanks John & Jeemy for your help but not sure the 'Easy to find' quote was quite right :!: :)
Not for an old boy anyway.
:cheers:
HiSpec front brakes
PNM rear brakes
Aluminium radiator
Kilimanjaro chip
Wannabe Princess
Postby TrevorB » Sat 29.03.2014, 16:37
Finally got around to replacing the (green) rheostat module today. But (there always is), dashboard lights still NOT working.
Relaced one of the known faulty lamps behind oil gauge thinking that might be the problem (christmas tree syndrome
one goes all go!?) no not the issue, still not working. Car is definitely working extremely well otherwise as I went for a quick
spin. Both sidelights and backlights are working.
Any more suggestions please. :? :?
:cheers:
Trevor
HiSpec front brakes
PNM rear brakes
Aluminium radiator
Kilimanjaro chip
Wannabe Princess
Postby Brit-Car-Nut » Sat 29.03.2014, 16:51
Technical, but the only way to know what is going on.
It is also possible the flexible circuit board is damaged.
Postby TrevorB » Sat 29.03.2014, 17:03
Thanks John, I'm going to need someone with electrical knowledge and volt meter to help me out here.
So may need to put a cry out for help. Good job that I don't go out in the dark very often and need to
see the dashboard at night.
Trevor
HiSpec front brakes
PNM rear brakes
Aluminium radiator
Kilimanjaro chip
Wannabe Princess
Postby donsladek » Sat 29.03.2014, 17:17
Trevor -
One easy thing to check is that the wires on the rheostat are still attached. I was mucking around in my dashboard, and one solder joint came loose, but the shrink tubing was still holding the wire to the rheostat, disguising the problem. I chased this for a couple of days...
Good luck!
Don Sladek
Calypso Red '91 #37594
donsladek
Postby TrevorB » Mon 31.03.2014, 19:58
TrevorB wrote:Thanks John, I'm going to need someone with electrical knowledge and volt meter to help me out here.
Are there any Kent/Essex/Sussex LECers with electrical knowledge who can help me out with this problem, obviously can travel :?: :D
Not urgent if I don't travel at night :lol:
:cheers:
Trevor
HiSpec front brakes
PNM rear brakes
Aluminium radiator
Kilimanjaro chip
Wannabe Princess
Postby Elanlover » Mon 31.03.2014, 23:25
TrevorB wrote:Finally got around to replacing the (green) rheostat module today. But (there always is), dashboard lights still NOT working.
:cheers:
Trevor
Having done a lot of customization of the panel lights I'm pretty sure its not the Christmas Tree syndrome at play here. Can you describe which lights work and which don't? (or did you state that and I missed it?) I'm thinking something like the status of:
1) Speedo cluster backlighting
2) Speedo cluster warning lamps
3) Some or all of the small gauges (turbo, oil, etc.)
4) Heater control backlighting
5) Fascia switch backlighting (emergency, A/C, etc.)
Postby TrevorB » Tue 01.04.2014, 21:56
All of the above have no back lighting. I have changed rheostat module also changed fuses #4 and #12 in Fuse Box 'A' Double checked that
control knob for panel lighting is turned up. The problem originally occurred when I went to fix a loose connection on lamp behind oil gauge.
I heard a click/pop type noise and that's when nothing worked. Have since changed that particular lamp.
Have again taken 'Merlot' out today and very happy that it's performance has not been affected by this problem.
So thanks for any further sugestions that I can try without it being too technical.
John C (BritCarNut) advice about voltage checks on rheostat switch, how does one get to the back of this to get to the wiring?
also mentions flexible circuit board, where is that?
Trevor
HiSpec front brakes
PNM rear brakes
Aluminium radiator
Kilimanjaro chip
Wannabe Princess
Postby Elanlover » Tue 01.04.2014, 22:13
TrevorB wrote: All of the above have no back lighting. I have changed rheostat module also changed fuses #4 and #12 in Fuse Box 'A' Double checked that
Trevor
So, I take it that the various telltale lamps work but its simply the panel lights (backlighting) that don't? Does the digital clock work? (do you have a turbo or NA version?) If you have a turbo (and digital clock) does it dim when you turn the headlights on?
With regard to the flexible circuit board, its the thing on the back of the speedo cluster (there's 2 of them actually) that handles all the electrical connections for the cluster including the backlighting. However, since you've got no backlighting on the other gauges as well its not likely the flexible board. While you're checking on the clock you might as well check fuses 6 and 7 (side lamps) since the feed for the panel lights are "somewhat" connected to them.
Postby Brit-Car-Nut » Wed 02.04.2014, 00:57
Trevor
Trevor: I am working on a guide to test the circuit but it is involved and I am testing each step to be sure I am not leading you astray. I will have it finished later tonight and will email it with pictures when I am done. It might be a bit much for you, but it is easier than it will seem. You might ask someone you know that is OK with electrical testing to do the tests, if you don't think you can do them yourself.
Postby TrevorB » Wed 02.04.2014, 07:52
Yes, all the lamps work i.e. battery, lights, ignition etc on instrument panel when ignition on, I did notice that the clock light does dim when
ignition is turned on and probably not related the cigarette lighter works as I had my phone plugged in charging. Side lights are fine so would
changing fuses 6 and 7 still make a difference?
John C has sent me via email (reply sent), a comprehensive guide to testing which will be very handy if a simple fix is not found and I go down the
electrician route.
Continuing thanks
:cheers:
Trevor
p.s. I am away playing in a golf competition next couple of days and Saturday taking 'Merlot' to first show this year so will check in again on
Friday.
HiSpec front brakes
PNM rear brakes
Aluminium radiator
Kilimanjaro chip
Wannabe Princess
Postby Elanlover » Wed 02.04.2014, 13:37
Since the clock dims you are likely getting all the right signals through the system and rheo module. If your side lights work then your fuses are ok.
My suggestion would be to look at the back of the dimmer knob itself as donsladek suggested. There are 3 wires running into the back of it and they are notoriously weakly connected and one or more often break off as they age. The problem is that its almost impossible to figure out unless the switch is out or you can get a great look at the back with a scope. The three wires are tie wrapped together so if one is broken off just pulling on it to see if it comes loose doesn't work. All three are tied together so even if one is still attached it will feel as all are attached. This would be the most likely culprit short of a wiring issue.
Postby TrevorB » Fri 04.04.2014, 21:01
Elanlover wrote:Since the clock dims you are likely getting all the right signals through the system and rheo module. If your side lights work then your fuses are ok.
Anyone have experience of getting to the back of the dimmer knob? It appears to be in the most inaccessible place without dismantling the whole dashboard. Surely that's not the route to take :!: Obviously there is a difference on LHD and RHD cars so I'm looking for help with the RHD.
At the moment I can survive without dashboard lights but there is going to be an occasion when I need them back so no rush.
:cheers:
Trevor
HiSpec front brakes
PNM rear brakes
Aluminium radiator
Kilimanjaro chip
Wannabe Princess
Postby Elanlover » Fri 04.04.2014, 22:48
Its hard to get at them - another one of those parts that's practically inaccessible without disassembling half the car. If you remove the binnacle cover then peer through the side of the front windshield you might be able to see it - if you're eyes are good. A scope helps if you have one or some type of magnifier. If you can slip a camera close (phone cam even) you might be able to get a picture of it. Or, you can try to feel around the back of the knob with your hands to see if a wire's loose.
This assumes that the knob is in the same relative position on UK cars as it is on a Fed version - next to the row of gauges along the top (oil, volts, etc.) If not I can't be of much help. :oops:
Postby GeoffSmith » Fri 04.04.2014, 23:45
Trevor, looking through the circuit diagrams and using some simple logic.... You're on the right path!
With reference to Sheet 9: All your sidelights are working therefore fuses A6 & A7 are OK.
With reference to Sheet 9 and Sheet 23: The digital clock dims when you turn on the lights therefore there is supply up to the splice in 38D for the rheostat - the sidelight warning light should also illuminates.
With reference to Sheet 22: All your backpanel lights are out so the problem is between 38D and 38H as it's unlikely to be a simultaneous failure in the switches, instrument pack and gauges.
You've replaced the rheostat module so it is likely to be the potentiometer/wiring/connections at fault.
If you can determine which are pins 6 and 8 on the rheostat module (I've got one out of the loft but can't see any numerical IDs on the module so the best bet is to get into the Lotus position and try and see where the Red/Black and Red/Purple wires go on the socket) then there should be 12V on pin 6 when the sidelights are on - as a temporary solution, put a wire from pin 6 to pin 8 instead of the rheostat module and you should get full illumination.
Otherwise you might want to read the Wiki!
Postby TrevorB » Sat 05.04.2014, 19:49
Thanks Geoff, I know what I shall be doing at the next opportunity - hunting down a potentiometer inside the binnacle. Maybe also resourcing
a new one.
:cheers:
Trevor
HiSpec front brakes
PNM rear brakes
Aluminium radiator
Kilimanjaro chip
Wannabe Princess
