Dasboard/Instrument Lights - replacement bulbs?
Re: Dasboard/Instrument Lights - replacement bulbs?
Postby Brit-Car-Nut » Sat 05.04.2014, 22:00
Trevor: The rheostat/potentiometer is part number A100M0097F and it is on the Aftersales List for £10.07 + VAT
Postby TrevorB » Tue 08.04.2014, 18:32
TrevorB wrote:
GeoffSmith wrote:
You've replaced the rheostat module so it is likely to be the potentiometer/wiring/connections at fault.
If you can determine which are pins 6 and 8 on the rheostat module (I've got one out of the loft but can't see any numerical IDs on the module so the best bet is to get into the Lotus position and try and see where the Red/Black and Red/Purple wires go on the socket) then there should be 12V on pin 6 when the sidelights are on - as a temporary solution, put a wire from pin 6 to pin 8 instead of the rheostat module and you should get full illumination.
Otherwise you might want to read the Wiki!
Thanks Geoff, I know what I shall be doing at the next opportunity - hunting down a potentiometer inside the binnacle. Maybe also resourcing
a new one.
:cheers:
Trevor
Brit-Car-Nut wrote:Trevor: The rheostat/potentiometer is part number A100M0097F and it is on the Aftersales List for £10.07 + VAT
Removed the rheostat/potentiometer today and ordered new part from local Lotus dealership. Not due to arrive until Friday so fingers
crossed this subject maybe closed by the weekend.
Trevor
HiSpec front brakes
PNM rear brakes
Aluminium radiator
Closed Loop conversion
Kilimanjaro chip
Wannabe Princess
Postby TrevorB » Fri 11.04.2014, 17:12
TrevorB wrote:Removed the rheostat/potentiometer today and ordered new part from local Lotus dealership. Not due to arrive until Friday so fingers
Trevor
Not good news :( Replaced rheostat/potentiometer today and still the problem persists. Presumably I have to go down the testing route
now :?: I shall have to investigate a good car electrician in the area and using the comprehensive instructions sent by John (BritCarNut)
hopefully get this sorted once and for all.
Unless of course anyone else has any ideas, although I feel that everything has been done.
:( and :?
At least the car is still running well. :-D
Trevor
HiSpec front brakes
PNM rear brakes
Aluminium radiator
Kilimanjaro chip
Wannabe Princess
Postby Elanlover » Fri 11.04.2014, 17:49
Befuddling to be sure.
If you have access to the electrical manual (and if you don't you should - you can request the manuals from a moderator like me) you can look up the panel illumination schematic on sheet 22 in the schematics section. If this is a case of not getting power to the lights there's really 2 places to test for current. On the Red/White wire that feeds the rheo module itself or the Red/Purple wire that feeds the panel lights after they are controlled by the dimmer knob (potentiometer). Obviously, you need a multimeter for that or some other way to test for current (like a little light bulb connected to the power and ground wires you want to test).
I suppose you could have a grounding issue from the black wire on the rheo module but that seems unlikely to me (it'll probably be that now that I've said it). The fact that you originally heard a "snap" of sorts one might think you may have a broken wire behind the dash but testing for current on those two wires at the rheo module location is a good place to start and perhaps easiest to reach.
Postby Brit-Car-Nut » Sat 12.04.2014, 19:55
How about it!!!!! Anyone close to Trevor in Kent that can lend a hand or recommend someone close to him to help out?
Postby Rice crispy » Sat 12.04.2014, 21:21
Trevor I have an old Meter I can bring next week to MBW if that helps
Rice crispy
Postby TrevorB » Sun 13.04.2014, 08:30
Brit-Car-Nut wrote:How about it!!!!! Anyone close to Trevor in Kent that can lend a hand or recommend someone close to him to help out?
lansledj wrote:Trevor I have an old Meter I can bring next week to MBW if that helps
I've exchanged emails with John C and shall invest in an electrical probe and will, after the Easter break, have an attempt at finding the
problem before going down the route of electrical engineer.
David, thanks that might be useful especially if we get an opportunity. (Looking forward to the Brooklands TLF MBW event).
Thanks everyone
Trevor
HiSpec front brakes
PNM rear brakes
Aluminium radiator
Kilimanjaro chip
Wannabe Princess
Postby TrevorB » Tue 29.04.2014, 17:33
Just a small update on this problem. I invested in a probe and some extension leads to get from the battery to the various points given to me
in an email from John C (BritCarNut). Once again the location of the harness where the rheostat module connects is difficult to get to and I
was unable to complete some of the tests due to its position under the dashboard and steering wheel. If you are able to look to see where it
is please do and imagine lying on your back in that small gap trying to put a probe into a small slot. It might help me for some suggestions on
what position is best, clean responses please. :lol:
I was able to complete one of the test only because it was inside the binnacle.
John has suggested removing the seat so as to get more room but I have been unable to get around to do this.
I will persist :!:
Trevor
:? :wink: :)
HiSpec front brakes
PNM rear brakes
Aluminium radiator
Kilimanjaro chip
Wannabe Princess
Postby Brit-Car-Nut » Thu 01.05.2014, 00:04
Trevor: I sent you a new email with pictures of the relay block with the pin sockets for the dimmer relay labeled.
Postby TrevorB » Fri 17.10.2014, 14:32
Hooray - Finally found a reliable auto electrician and today was able to get the dashboard lights looked at. He identified that there is
a problem between the rheostat and dashboard connector (red/purple lead). So he has put a bridge between sidelight (red/white lead) and
rheostat lead which has put power to the dashboard lights but bypassed the dimmer knob (potentiometer). Obviously not a permanent fix
but at least I now have dashboard lighting.
If anyone knows of the best way to get behind the module pack which holds the rheostat module to see if there is a problem with the wiring
e.g. dry joint on this red/purple lead the problem could be permantly fixed.
But, at the moment another problem has been solved after over year of it being around.
John C, thanks for the drawings they helped in todays quest.
Photo attached of the bridge with 5 amp fuse in line for safety.
HiSpec front brakes
PNM rear brakes
Aluminium radiator
Kilimanjaro chip
Wannabe Princess
Postby V8vroom » Thu 10.09.2015, 13:31
thanks for this write up!
I have a problem with my dash lights coming on automatically with the ignition on (even if the light switch is turned to off) and the dimmer knob doesn't work at all - however, at least I have an illuminated dash when going into a multi storey car park without having to turn the main lights on!
They luckily seem to turn off when the ignition is off so the battery isn't drained....
R :D
Lotus Elan S2 No. 513 Norfolk Mustard
V8vroom
Postby Brit-Car-Nut » Thu 10.09.2015, 14:04
All of the S2 models had a modification that turns on the dash lights when the key is turned on. Lotus said it helped to cut down on instrument fogging. They provided a service bulletin for modifying the SE to do the same thing.
Trevor: You probably would have to remove the dash to get to the wiring and relay blocks to fix the broken connection. The dash rheostat circuit doesn't put full power to the dash lights even when on "full" brightness as the bulbs get a bit hot. When we were looking at making a replacement module, we measured the power at 60% duty cycle when on full bright. Adding a resistor is possible, but it will get really hot too and could cause damage. Try to get the real problem sorted soon so you don't end up with burn marks on the gauge faces.
Postby V8vroom » Thu 10.09.2015, 15:42
Brit-Car-Nut wrote:All of the S2 models had a modification that turns on the dash lights when the key is turned on. Lotus said it helped to cut down on instrument fogging. They provided a service bulletin for modifying the SE to do the same thing.
Thanks Brit-Car-Nut - most useful info! So just need to get the rheostat working now and a few instrument panel lights, oil pressure light, heater control lights and it'll be like new ! :lol: :lol:
V8vroom
Postby Brit-Car-Nut » Thu 10.09.2015, 17:31
Rheostats (A100M0097F) are still available for £10.89. Unfortunately, the modules (A100M6059F) are now obsolete. Matty, SJs or SW Lotus probably have stock - they were £7.65 while on the aftersales list.
For anyone electronically adept, the modules have a zener diode that fails and can be replaced which should get the module working again.
Postby GeoffSmith » Wed 23.12.2015, 18:11
SJs say they have them in stock.
Postby paulg » Sat 04.03.2017, 11:42
I recently ran out the washer fluid and the far left yellow warning light came on. When I refilled it the warning light still comes on, except for when you are pulling the lever forward to do the spray and four wipes, any ideas please?
paulg
Postby lotusflasherman » Sat 04.03.2017, 12:52
paulg wrote:I recently ran out the washer fluid and the far left yellow warning light came on. When I refilled it the warning light still comes on, except for when you are pulling the lever forward to do the spray and four wipes, any ideas please?
There are two different wiring arrangements. Suggestions will depend on which you have...
This thread may help - washer bottle pump & light
