Elanlover wrote:I take it then that its simply straight cable, no "mystery lump" hiding a diode like the parts manual shows...
GeoffSmith wrote:Elanlover wrote:I take it then that its simply straight cable, no "mystery lump" hiding a diode like the parts manual shows...
What diode?![]()
http://wikilec.9600.org/images/7/79/MJ2 ... nition.gif
EDIT: Or are you mistaking the alternator stud cap in John's fourth picture and shown retracted back down the cable to reveal the clamping nut and washer in the parts manual?
Brit-Car-Nut wrote:I don't think it was electrical heat that caused the darkening although the insulation has shrunk at the eyelet.
I didn't see any diode around the alternator end but someone might have added a supression capacitor if they were getting noise in their sound system.
The end hiding in the boot is a regular eyelet just like the one at the other end. Remember, wire sizes in the UK are different than US. Their stranded wire has a lot more strands than most US cables I have worked with so can handle higher loads for the same outer diameter.
I will get you some numbers.
Looking at the write-up for starter replacement, the distructions start with removing the prongeron. I know it has to come off to get the started out and in, but might be the easiest way to reach the bolts and connections. The picture of the cavity show it after the starter was removed, so I don't know if it installs solenoid up or down.
Brit-Car-Nut wrote:Dug out the cable again and wiped the soot off the starter end. It was grease and soot. No suggestion the wires got hot after they were crimped
The large wire is stranded but a bit over .25 inches which suggests #2 and the small wire is also stranded but could be #6. Stranded gauge is not the same since they calculate the equivalent cross sectional copper area which means each strand is calculated and then added together. I think that would make it closer to #1 or #0 and # 5 or #4 for the small wire. The strands are really thin, so a lot of them to add together.
Found another chart that shows 196/0.4 as a metric size and it is equivalent to maybe a 3ga?
I found the cable from the UK car but it was hacked off at the starter eyelet. Since it was out of the plastic sleeve, it revealed there is a fabric jacket around the two wires inside the plastic jacket. Pulling a new wire into the existing sleeve might be more difficult than expected.
Brit-Car-Nut wrote:I don't know if you can reach the nut without major disassembly. Hopefully, someone who has done the task will step up and give a review.
The wire diameters are all the BARE wire without the jacket. The main wire is just over .25" using a reliable caliper the jacket makes it .391". The small (alternator) wire is .141 bare and .227 with jacket.
If you need it, I can measure each length as I think you are a bit optimistic. I believe the connection eyelets need to be considered in your calculations since none of those in the starter/alternator bundle were soldered - they are all just crimped.
The engine to chassis cable needs to be considered. I assume it is braided so very flexible. What is it's effective current capacity. Can you get a heavier brade with decent eyelets to either replace or supplement the stock one?
Also, the jacket material needs to be analyzed as regular vinyl is not happy with high currents and I have never seen a teflon (THHN/THWN) battery cable. Maybe just adding a safety conduit would help?
Why are these questions being posed? To go to a heavier load starter or heavier output alternator? Certainly (hopefully) not to support some audio amplifiers! The last thing we need is another noisy car in the parking lot.
Its not like I used the trunk for anything Brit-Car-Nut wrote:Re-read my edited reply. The feed from the +ve post to the starter is longer than 3 feet, so ...
I would go with PLAN "B" and run a heavier gauge wire from the alternator to the starter but that might require removing the clam and possibly removing the engine.
Not much room available to design and fabricate solutions when the car is assembled.
Brit-Car-Nut wrote:the small wire is also stranded but could be #6
Brit-Car-Nut wrote:Geoff: The link to the Wiki is not working
GeoffSmith wrote:http://wikilec.9600.org/images/7/79/MJ25-02_Starter%2C_Alternator_%26_Ignition.gifBrit-Car-Nut wrote:Geoff: The link to the Wiki is not working
It's working for me at home and I'm sure if I tried at work, it would most likely work there too.![]()
Anyone else having problems with the link?
Brit-Car-Nut wrote:The small wire is crushed in the crimp, so I did the best I could measuring and subtracting the eyelet thickness. If it was a solid conductor, then #7 is most likely the right gauge. It is Stranded, so the gauge gets better. Probably a sound #6 but even possibly a #5. It IS noticably smaller in diameter than the main feed (as would be expected).
Even a #4 is only safe for 95A (#6 - 75A; #8 - 55A) and that is with a decent insulation jacket. I am concerned you won't be able to find decent eyelets rated for 100+ amps that are small enough and have a small enough hole to make the studded connections. How realistic is the charging capacity of the alternator in question? 165A charging requires a HUGE alternator. Efficiency has improved in recent years, but I think you are being misled by what can be done with an alternator that fits in the space. The largest up-rated alternator I found for the GEO that would fit the space we have was 85A although I see listings for 105 and 120 amp units but they are HUGE and require different brackets and a LOT of room.
