Fan timer and turbo cooldown timer
Postby maz_r » Thu 28.08.2014, 19:18
I have posted a couple of times previously about this topic and I have finally had time to give it some concerted effort.
I have a prototype built that does the following:
If the ignition is on, a quick press of a switch will energise the fans for 45 seconds and then switch them off
If the ignition is on, a long press of a switch (~3 seconds) will energise the fans for 5 minutes and then switch them off
If the ignition is off, a long press of a switch will energise the coolant pump for 5 minutes and then switch off
If the ignition is switched off AND the ignition has been on for more than 5 minutes, run the coolant pump for 2 minutes and then switch off
Any change in ignition (off to on or on to off) will switch off the fans or coolant pump
Any press of the switch while the fans or coolant pump are running will turn them off
If the fans or coolant pump are running, an LED flashes to indicate that they are active.
The idea is two-fold:
Firstly, to give a manual override to the temperature sensor that drives the fans normally, just in case your heart can't take the strain of hoping the fans cut in, as the temp gauge edges ever higher....
Secondly to run the auxiliary coolant pump if the car has been running for a while to exercise the pump (have you checked yours recently?? There is a high chance it is seized :)) and to run coolant through the turbo even though the car isn't hot enough to trigger the 'normal' cooling down (hang on - is that 3 reasons? Nevermind)
What needs to be connected up is permanent 12v, switched 12v, ground, switch, LED and a connection into the loom to activate the fans/pump, which sounds like a lot, but most of these are conveniently available on the digital clock connector or local to whatever manner of switch and LED you decide on. The best possible solution is to find a switch to match the other switchgear and, fortunately, there is such a thing in the form of the rear window demister switch from a Senator; it is a momentary switch and has a build in LED - just the job and you can even wire up the switch illumination to come on with the lights.
So after that quick overview, I wondered if there would be any call for a kit to make up your own? It will be a kit as I'm afraid I just don't have the time to construct them. The kit will include everything EXCEPT a switch, LED and hook-up wire (pick your own, but suggestions are available :)). Having sat down and been through all the parts and done a rough calculation and the parts come to around £25, assuming that there is enough interest to make the manufacture of the PCB economic.
Appreciate that pictures are worth a thousand words, so I will try and upload some later - frankly one PCB looks much like another, but hey-ho.
Feedback welcome, and open to adjusting the timings for the various on and off functions as they are simple to adjust.
Thoughts?
maz_r
Binary Bodger
Re: Fan timer and turbo cooldown timer
Postby dapinky » Thu 28.08.2014, 20:04
we'd better have a list, then :D
1) pinky
2)
Postby Rambo » Thu 28.08.2014, 20:05
Over to you Smiffy ;-)
Postby epipete » Thu 28.08.2014, 20:27
dapinky wrote:we'd better have a list, then :D
Just what I've been waiting for. :bowdown:
1) pinky
2) epipete
3)
Postby RayD » Mon 01.09.2014, 21:33
Well done Maz
With regard to fitting a switch on the dash there's a picture of mine on here.
It still lacks an LED to show it's working.
The original fans appear capable of over-cooling the engine so the timing will need to be tested ... I have a feeling 5 minutes is more than enough.
Postby maz_r » Thu 11.09.2014, 23:36
Bump....especially in tb10's direction...... :-D
maz_r
Binary Bodger
Postby tb10 » Fri 12.09.2014, 07:22
maz_r wrote:Bump....especially in tb10's direction...... :-D
Hi maz_r,
Ok, Ok............. that'll be four on the list then!! :cheers:
1) pinky
2) epipete
3) tb10
4) tb10
Yes, this is a really good idea and well worth the investment IMHO.
regards
tb10
Postby rip » Fri 12.09.2014, 07:54
I think 5 minutes may be too long for running the fans or pump & feel 2 minutes may be better.
Some experimentation with the prototype will give a better feel for this.
This sounds particularly useful to stop the engine temperature climbing while sitting at traffic lights.
1) pinky
2) epipete
3) tb10
4) tb10
5) rip
Postby JohnB » Fri 12.09.2014, 10:41
This sounds particularly useful to stop the engine temperature climbing while sitting at traffic lights. :agree:
1) pinky
2) epipete
3) tb10
4) tb10
5) rip
6) JohnB
Anybody going slower than me is an idiot. Anybody going faster is a maniac.Image
JohnB
Postby woody » Fri 12.09.2014, 11:59
Count me in, looks like a good idea.
1) pinky
2) epipete
3) tb10
4) tb10
5) rip
6) JohnB
7)Woody
woody
Postby cliff » Fri 12.09.2014, 18:59
Me too.
1. pinky
2. epipete
3. tb10
4. tb10
5. rip
6. JohnB
7. Woody
8. Cliff
This might be useful for the switches
http://www.ebay.de/sch/i.html?_odkw=sen ... r&_sacat=0
Swapped the brackets for a full stop as I kept getting a smiley instead of an 8. :?
91 Lotus Elan SE Turbo
07 Alfa Spider 939
cliff
Postby novacaine » Fri 12.09.2014, 22:23
Sounds pretty good to me
1. pinky
2. epipete
3. tb10
4. tb10
5. rip
6. JohnB
7. Woody
8. Cliff
9.Novacaine
novacaine
Postby G UK » Mon 15.09.2014, 21:49
1. pinky
2. epipete
3. tb10
4. tb10
5. rip
6. JohnB
7. Woody
8. Cliff
9. Novacaine
10. G UK
https://gridcoin.ddns.net
G UK
Postby maz_r » Mon 06.10.2014, 21:36
Folks,
I apologise for the lack of progress on this. I have done my back in and haven't had a chance to fit the prototype into the car, and until I've done so, I can't guarantee it all works as expected. I have no reason to doubt it will do the job but obviously I'm not going to start taking orders on an unproven design.
I will post another update as soon as I can get everything fitted in and working as we want.
Sorry again
Martin.
maz_r
Binary Bodger
Postby dapinky » Mon 06.10.2014, 22:14
Martin,
No need to appologize, we all have lives to lead outside of our hobby.
Work, Family and health are all more important (in whicever order you wish to put them)....
....besides which, my car isn't going to need one for a while - i dropped it off to the painter today, so won't be seeing it for a fair few weeks!!!!
Get better soon.
Postby andy111s » Tue 07.10.2014, 06:22
1. pinky
2. epipete
3. tb10
4. tb10
5. rip
6. JohnB
7. Woody
8. Cliff
9. Novacaine
10. G UK
11. andy111s
I'm sure you have it all in hand, but if you need any assistance with procuring components, routing / etching the PCB's etc, let me know as I may be able to help for what it is worth...
andy111s
Users browsing this forum: AhrefsBot and 7 guests
