USB Fast Charger Upgrade [how to install]
Postby Tuga2112 » Mon 29.06.2015, 20:14
Hello fellow enthusiasts.
Just another small Electricall upgrade i done In my Elan,
This one is designed for those who use the phone in the car, either as a satnav or as a music devise to plug to the radio.
Im sure you guys noticed that those cigarrete lighter USB chargers are damn slow to charge a phone.
I came acrossthis little gadget while wandering through fleabay looking for colored electrical wires.
After some investigation on power over USB I concluded that 3amps was the top available on current specs, from experience the mains plug is a hell lot faster to charge than the multiple cigerrete adapters i have. (ranging in prices from £1 to £5 ) making me reash the assumption that this particular charger cant be slower than the mains plug.
Now to the instalation process.
this is incredibly easy, as the radio is one of those periferals that is most changed, most of us will be able to take it off without any problems.
From the electrical manual (page 21) we know that the puple wire is a constant feed to the radio (memory) and black is as usuall earth.
there is also the live feed from the radio through the ignition switch as an alternative, although i do not know the color of the wire.
I tapped into the "always on" purple wire using a scoth lock and another scotch lock to the black and voila, power is on.
I then put all the wires back into the fascia panel and brought out the 2 USB connectors from the side, without damaging anything just to keep the parts all as stock as possible.
An alternative for all those who do not worry about keeping the car as stock as possible is to make some holes in the ashtray and put the URBs hidden in there.
I did not bother with that although i have a spare ashtray interior bit in the garage.
And here is a couple of pictures to show the wiring and end result.
It is worth noting that your wiring will probably be a log cleaner than mine, a previous owner must have installed an aftermarket radio in a very crude DIY way as the radio i had there previously did not have a ISO connector and other owners tell me the cars came from factory with ISO connectors, i simply took out everything from the previous connection and put my own ISO connector there using the bullet connectors i had at hand. not a pretty job but no one will see it but me :)
PS.
If anyone has some spare switches (the fog light type) let me know.
im thinking a fog light switch connected to the circuit would allow feedback to us when the power is on, and control over it manually which would allow you to avoid draining the battery in case you forgot the phone in the car overnight. (both problems can be sorted by wiring the usb to the ignition, but that wouldnt be fun..)
Re: USB Fast Charger Upgrade [how to install]
Postby Tuga2112 » Mon 29.06.2015, 20:23
I forgot to mention in the post.
after doing this mod it may be worth considering changing the fuse of the radio from 5to 7.5 amps, if the USB charger takes 3amps there will be little juice left over for your tunes before the fuse blows.
Now let's find out from the most knowlegable people in the forum pointing if there are any reasons not to do this that i never considered. :-)
Postby GeoffSmith » Mon 29.06.2015, 22:05
You could always put a switch in the A/C position and you'll get a 3A switchable ignition output under the binnacle.
Your charger is a 15W device so you only need ~1.25A from the 12V supply.
Postby Tuga2112 » Tue 30.06.2015, 11:32
GeoffSmith wrote:You could always put a switch in the A/C position and you'll get a 3A switchable ignition output under the binnacle.
unfortunately i do not have any spare carlton switches, and the prices in fleabay are not the most appealing either, not particularly steep, just annoyingly priced considering the price of a normal switch.
this issue will be sorted when i get my laziness sorted and do the fascia panel mod :P
GeoffSmith wrote:Your charger is a 15W device so you only need ~1.25A from the 12V supply.
your right there, i looked at 3ams output, but that is after converting to 5 volts so your right. the normal fuse may be enough for both devices.
Postby rip » Tue 30.06.2015, 12:55
Tuga2112 wrote:the radio i had there previously did not have a ISO connector and other owners tell me the cars came from factory with ISO connectors,
Yes, it sounds like someone has removed it.
My Elan already had an ISO connector, so did my 1989 Cavalier & both my 1995 Calibras & their wiring all looks similar, so I think it is reasonable to assume they were standard on GMs built around then.
Postby lotusflasherman » Tue 30.06.2015, 19:53
:agree: Original Fitment on SE was Pioneer that used ISO so dead easy to replace with Blaupunkt etc..
I've got a Blaupunkt Brisbane Radio/SD/MMC/MP3 that came with several leads that plug in the back so I plugged them in and fed them through the back of the glove box and that's where the phone charging lead is too.
On the load in amps topic - most cheap multimeters will read 10 amps so you can see whether the theory and facts about current agree or not.
Postby CalElan » Tue 30.06.2015, 20:43
rear foglamp switch currently available from SJSportscars
B100M6004F
@ 6.57 each
CalElan
Postby John_W » Tue 30.06.2015, 20:47
The original fitment radio-cassette in the SE was Clarion of standard or upgraded versions or Blaupunkt. See this thread viewtopic.php?f=21&t=19310 . Clarion was also used in the Esprit, and I think that Clarion is even the standard fitment in the Evora.
When I replaced my old original Clarion in my 1991 SE with a Pioneer radio-CD unit many years ago, there was no neat plug arrangement. I had to reconnect every wire into the new Pioneer plug. Presumably Rip's originally had the Blaupunkt.
Users browsing this forum: AhrefsBot and 16 guests
