Washer bottle pump ?
Postby simonbuk » Thu 08.09.2016, 21:34
For some reason I have no washer fluid being sprayed onto my screen.
Do the pumps just fail and stop ?
Is there a fuse ?
Oddly enough the washer bottle light on the dash started to flash intermittently AFTER I filled the bottle from about a 1/3 full to 3/4 full. (It wasn't flashing when it was (1/3 full).
I know SJs sell them for about 18 quid but have seen them on ebay for about 8 as well 'supposedly' for Elans.
Black S2 No.357
Aqua Blue S2 No.385
Simonthesailor
simonbuk
Re: Washer bottle pump ?
Postby lotusflasherman » Fri 09.09.2016, 02:10
Wiring diagram is on Sheet 8 of Section MJ of Service Notes.
Only fuse involved is 15 amp Fuse A17 (in passenger footwell) that feeds Wiper Motor, Wash/Wipe Switch, Intermittent Wipe Module, washer pump, washer warning relay, warning lights etc.. so if that fuse had gone nothing to do with wiping and washing would function at all. There is no separate fuse to do with pump.
There is a Screenwash Warning Lamp Relay that is "by the R/H rear lamp cluster (RHD)" with a relay coil that sits across the Screenwasher pump - haven't yet worked out the complete functionality but both pump & relay have a yellow/light green wire in common on the supply side and a black wire on the earth side. Suggest you check connections to pump and relay and where these wires join together as a bit of corrosion on a terminal might stop pump working but still initiate warning lamp relay.
If I get a chance I'll have a look at mine tomorrow with a multi-meter. The wiring diag shows an ignition supply to the Screenwash Warning lamp and that will only come on when an earth return is provided when the Screenwash Warning Lamp Relay pulls in, coincident with pump being energized, AND the Low Screen Wash Switch is closed. So the warning light should only show when you try to wash with low fluid level ... but mine gives me a warning light that is on permanently until I add fluid so need to investigate before I can comment further... the theory (diagram) doesn't fit the facts at the moment .. :banghead:
Postby peteoddcar » Mon 26.09.2016, 22:28
The low washer lamp will only illuminate when the washer pump switch is pushed and the relay contacts close, when the level switch senses that the level is low.
There's a good reason for this set up. If the level switch were permanently connected to the lamp and given a permanent ground when the fluid level is about half way the light will flash as you corner. It should have had a delay system like fuel lights have but this was a last minute Press Car fix we did to prevent negative comments from the Press.
We decided that it should go onto the production cars until a smarter solution could be released.
If you look you will find that the jumper loom with the relay has a female connector to the pump pull this off the pump dig around with a torch find the one that connects it to the body loom unplug that and put the body loom connector 2 way onto the pump and that will eliminate the jumper loom.
The pump is a generic Vauxhall part late 80s If I recall correctly.
peteoddcar
Postby lotusflasherman » Tue 27.09.2016, 00:38
:agree: Pete that's what the diagram says should happen and it's a good idea .... but my current use SE (with orange wheels) needed water in the bottle to put the light out on my trip to Brands Hatch. It came on permanently and I don't like a warning light in my peripheral vision even if I know what it is. Adding water put the light out. I'll come to the next pub meet with low water and show you ...
Postby simonbuk » Tue 27.09.2016, 08:24
And my light wasn't on but when I filled it up it started to flicker!!
Black S2 No.357
Aqua Blue S2 No.385
Simonthesailor
simonbuk
Postby Rambo » Tue 27.09.2016, 08:48
lotusflasherman wrote:It came on permanently and I don't like a warning light in my peripheral vision even if I know what it is ...
Neither do I. That's where black insulation tape comes in handy :wink:
Postby GeoffSmith » Tue 27.09.2016, 11:27
lotusflasherman wrote::agree: Pete that's what the diagram says should happen and it's a good idea .... but my current use SE (with orange wheels) needed water in the bottle to put the light out on my trip to Brands Hatch. It came on permanently and I don't like a warning light in my peripheral vision even if I know what it is. Adding water put the light out. I'll come to the next pub meet with low water and show you ...
:agree: Didn't make it onto my S2 either.
Postby lotusflasherman » Tue 27.09.2016, 12:35
Thanks for the comment Geoff. Made me look in my Electrical Manual that includes Supplement for '94-'95 Elan S2 that Lotus sent me, along with Supplement for Esprit & Esprit Turbo '90 Onwards - I never worked out why but interesting and helpful when I found a bit of Esprit loom in my late '93 SE :banghead:
Seems my 'facts' fit the theory of the S2 wiring diagram, which has a Delay Module to stop the 'flashing when cornering' that Pete mentioned but WL comes on permanently when water is low.
That's solved that conundrum...
Extra note for Simon... Can't explain why your light would flash intermittently after you topped it up, but you'l see on the S2 the warning light wiring is completely separate from the washer pump circuit so what I said in my first reply was correct for the (early) SE but bollocks for the S2.
Postby peteoddcar » Tue 27.09.2016, 19:38
When is the next meet? Assuming the same location
My Elan has gone to bed for the winter at the end of this week.I will bring my Circuit tester.
peteoddcar
Postby simonbuk » Sat 15.10.2016, 21:07
Well my new pump arrived from SJ Sportscars, different size, different electrical connectors, different size outlet to go into the container.
Fortunately my original started working again !! Woo-hoo !!
Black S2 No.357
Aqua Blue S2 No.385
Simonthesailor
simonbuk
