Immobiliser ‘key’
Immobiliser ‘key’
Postby AllenG » Fri 26.07.2019, 11:35
Hi guys. Been enjoying the lotus in this fine weather, however becoming paranoid that I only have one immobiliser ‘key’. Does anyone know if I can buy a second one or if there is a way to do some thing which removes the need for it. Worried that if it gets lost I’m stuck!. It’s the type that you plug into a hole near the ignition switch then remove and start the car with the ignition key. It looks like a jack plug.
AllenG
Re: Immobiliser ‘key’
Postby RonR » Fri 26.07.2019, 11:48
If it's the standard S2 alarm, have a look at AVS-Gemini Here
Postby AllenG » Fri 26.07.2019, 13:38
Thanks RonR, none of those. This seems to be an immobiliser ‘key’, I have a separate alarm key. Have tried to upload a photo of the ‘key’ but file too big. As I said, it looks like a jack plug similar to what would be on older headphones or for plugging an electric guitar into the amp, with a little plastic key fob, no battery needed.
AllenG
Postby Brit-Car-Nut » Fri 26.07.2019, 16:28
Here is a picture of his key:
Lotus Manuals
Postby John_W » Fri 26.07.2019, 23:21
Where did that come from? Never seen one of them in me puff. Is it an S2 thing.
Postby woody » Sat 27.07.2019, 06:25
No, not an S2 thing. Must be a custom made immobiliser. We used to fit similar immobiliser keys to Landrovers, when we used them underground in Gypsum, and Potash Mines.
Cheers,
Woody
woody
Postby Saltire » Sat 27.07.2019, 07:23
This isn’t an SE or S2 standard fit ‘key’; I would think it’s a third party add-on.
If there’s no battery, that suggests it’s a dumb key, which is just making a circuit by connecting (or disconnecting) two parts of the the plug together. As a matter of interest, do you have to leave it in the dash in order to drive the car, or is it “push in and remove” to energise?
The plugs themselves are widely available; for example here on eBay. if my suspicions are right, buying one of those and bridging two of the plug terminals would give you a spare key. You’d need to experiment with a multimeter or dismantle the existing plug (if it comes apart) to find out which two terminals.
1995 Elan S2 no 512, BRG/magnolia, last of 4 UK S2 to this spec - SORN
2019 VW Golf R - “The Flying Tomato”
2020 Volvo XC40 T4 AWD
Postby AllenG » Sat 27.07.2019, 08:54
Thanks Guys, the car is an 92 SE Turbo. To make the ignition work, you push this into a fitting which has been mounted just forward of the ignition switch, then remove it, insert ignition key and start as normal so yes it is a “dumb key”. It doesn’t come apart the plastic is a one piece moulding. If you don’t follow this procedure and just go straight to ignition key the car is dead, nothing happens. Will look at getting a jack plug from eBay and having a play. As I said in the original post everything works fine I’m just paranoid about losing this thing and not having a spare. Cheers :D
AllenG
Postby dapinky » Sat 27.07.2019, 11:38
I remember having one of these on one of my old cars (Can't remember which one, but it was one of the Sprints)....
... IIRC it was more than just a totally dumb connection, but I can't recall what it consisted of, how it worked or what was needed to replicate it.....
.... so, I'm not really much help here!
Postby KenCarson » Sat 27.07.2019, 12:05
Are you sure it is a totally 'dumb' key? I have an Autowatch immobiliser, the touch key has no battery but has to be programmed to the immobiliser code. The code will be on the brain of the alarm (although I have no idea where that is on mine!) Abacus Alarms https://abacuscaralarms.co.uk/ may be able to advise.
KenCarson
Postby Jamie N » Sat 27.07.2019, 12:20
I have encountered a couple of these on the dash looms when doing Honda engine conversions, they are pretty simple and easily bypassed, if you lost the only key you have it wouldn't be very difficult to remove the complete thing and put the wiring back to standard.
There is an even better solution... Get a company to fit an up to date alarm / immobiliser to your Elan, they will remove the antiquated set up
you currently have, providing you with far better security with up to date technology, along with spare fobs, job done.
Might even reduce your insurance premium. ;-)
Jamie N
Seal God
Postby AllenG » Sat 27.07.2019, 16:24
Thanks everyone, I’ll keep enjoying it through the summer and I think I’ll go with Jamie’s suggestion of getting a modern alarm/immobiliser fitted
AllenG
Postby Saltire » Sat 27.07.2019, 22:18
Jamie N wrote:I have encountered a couple of these on the dash looms when doing Honda engine conversions, they are pretty simple and easily bypassed, if you lost the only key you have it wouldn't be very difficult to remove the complete thing and put the wiring back to standard.
:agree: with Jamie. I have done this (on an S2) and it’s much better than OEM. It links into the central locking, provides alarm and immobiliser, gives me a remote boot release and even auto window closure - all working off the key fob. Best of all, you can program up to 4 fobs yourself for added peace of mind.
Postby John_W » Sun 28.07.2019, 10:39
What's the make and model, Jonathan?
Postby Saltire » Sun 28.07.2019, 22:33
John_W wrote:What's the make and model, Jonathan?
Sorry, should have said; too much Bunnahabhain last night :oops:
Toad Ai606T2
Postby John_W » Mon 29.07.2019, 13:28
Thanks - It’s always good to get a recommendation from somebody who’s fitted a piece of kit they find is good!
Postby Saltire » Mon 29.07.2019, 19:06
If you’re seriously considering it, drop me a PM. I have all the details of how I did it in electronic format suitable to go on a USB stick (too much to email).
Postby AllenG » Sun 11.08.2019, 17:03
:roll: As per one suggestion I got a standard quarter inch jack plug, tried that and not surprisingly the car didn’t start. Tried again with the proper key (jack plug) ......car didn’t start. Disconnected car battery and reconnected, car started. Then discovered car can be started without first inserting/removing the immobiliser key! So I’ve killed the immobiliser :? . Not too concerned as I no longer need worry about the loss of the key.
AllenG
Postby Tuga2112 » Mon 12.08.2019, 13:04
the simplest way to confirm if its a "dumb key" would be to just put a multimeter across the 2 sections and check for continuity.
from the description i've read it does not sound like a "dumb key" design, i suspect theres an integrated circuit chip inside that connectes to the alarm giving the password required to authorise the +ign connection to establish.
1991 elan se
1991 elan se project
91 MR2 Turbo (import) project
94 Celica GT4 (Import)
94 4Runner
98 Celica SR
Postby RonR » Mon 12.08.2019, 15:16
The plug in the supplied photo is a "Stereo" version, which has 3 connections (L, R and Gnd)
If a 2 connection "Mono" plug was used to test, it would short out 2 of the 3 connections, even if no wiring was attached.
