New exhaust for S2
New exhaust for S2
Postby Braxted » Tue 24.07.2018, 19:21
I'm new so be gentle!
I might be buying a 1994 S2 which needs a new exhaust, can anybody recommend a decent stainless steel exhaust?????
1968 Lotus Elan plus 2
1995 Lotus Elan S2
2004 Land Rover Defender 90
2017 Audi A4
Braxted
Re: New exhaust for S2
Postby MPx » Tue 24.07.2018, 19:59
Plenty of people on here have them. If you are going to go on the well trodden upgrade path (with other work like chip/wastegate/brakes) then you can get a Piper or Peco (Cybox) 2.25" or 2.5" system. You might choose to also put in a pre-cat eliminator (which is basically the same shape as the original pre-cat bit with no innards) and you can replace the main catalyst with a sports cat. All of which might make MOT testing a bit marginal and they can be louder particularly the 2.5. If you want to stay standard then fit a 2 inch system with both pre-cat and main cat in place - in which case SJ Sportscars can sell you what you need in SS or mild.
Good luck...
Mike - MPx
95 M100 Elan S2 (423)
86 Turbo Esprit
MPx
Postby Rambo » Tue 24.07.2018, 20:22
I can thoroughly recommend the Piper system. Also the Cybox, and its precursor, the Peco (no longer available but essentially rebranded as the Cybox)
If you are averse to too much noise then you can get an additional silencer
Postby Giniw » Tue 24.07.2018, 22:14
Please be aware that an enlarged exhaust bore might cause boost creep though, so you might need to port the wastegate.
Giniw
Postby dolmerob » Mon 10.12.2018, 04:19
Any update, OP? Cybox gets my vote. It is a nice-sounding exhaust.
dolmerob
Return to Exhaust
