Piper Exhausts turbo downpipe development thread
Re: Piper Exhausts turbo downpipe development thread
Postby paulsmithmk » Thu 20.09.2012, 11:27
will call you and order - god Im an easy touch!!
PiperRS wrote:
paulsmithmk wrote:
so I could fit this to my S2 and have a totally new system - am wondering if I should have odered after all now?!!
As mentioned, it can be fitted after our exhaust has been fitted (although it will be easier to do it all in one go!)
I have these in stock ready for dispatch if you wish! Il even offer you free postage with it! (saving £15!)
S2 Number 640
paulsmithmk
Postby trig » Thu 20.09.2012, 13:41
[quote="paulsmithmk"]will call you and order - god Im an easy touch!!
[quote="PiperRS"][quote="paulsmithmk"]
Paul as your an easy touch could you dyno run your car before and after fitting the Piper-down pipe :wink: :wink: :)
Very good idea to do the lot in one hit ,, incl porting , I'm sure this will transform your car
trig
Postby Steve A » Thu 20.09.2012, 13:48
Thanks for the info, so now the big question is what are the performace figures :poke:
When you getting yours fitted paul :poke:
Postby paulsmithmk » Thu 20.09.2012, 14:17
Very good idea to do the lot in one hit ,, incl porting , I'm sure this will transform your car[/quote][/quote][/quote]
I have no turbo boost currently due to a suspected cat breakdown...so guess transformation will happen!!!
S2 Number 640
paulsmithmk
Postby paulsmithmk » Thu 20.09.2012, 14:18
Steve A wrote:Thanks for the info, so now the big question is what are the performace figures :poke:
Being fitted on 1st October - I hope :-)
S2 Number 640
paulsmithmk
Postby paulsmithmk » Fri 21.09.2012, 13:45
OK so I have jsut had a call from the garage - my stuff has arrived (hoping down pipe was in there also?) - thanks guys for delivering ahead of time :-) BUT they are making teh portign of the wastgate into a big job - may be difficult to get turbo off and then they need to send it away etc, etc. So:
just going to get them to swap the system and see what happens and report back on here.
Then if it does need porting (likely) can anyone help me please!
Paul
S2 Number 640
paulsmithmk
Postby rip » Fri 21.09.2012, 13:53
I've not taken a turbo off either. Getting off the seized studs will be the tough bit.
Once off, porting the watsegate is just a matter of half an hour with a grind wheel, no need to send it anywhere.
I'm certainly willing to give you a hand but it will be a learning curve for both of us.
Postby paulsmithmk » Fri 21.09.2012, 13:57
rip wrote:I've not taken a turbo off either. Getting off the seized studs will be the tough bit.
Hope you have lots of patience rip!!! appreciate that thanks...I will supply food and beer!!!
S2 Number 640
paulsmithmk
Postby cliff » Fri 21.09.2012, 19:15
Piper removed the my old downpipe, so I don't really know what is involved in that apart from a lot of swearing.
I took my turbo out a while back though and found it pretty straight forward. The new downpipe makes the job much easier. Once the turbo bolts were loosened, I found it easier to remove them with a 1/4in drive rather than a 1/2in drive. Disconnect the water pipes at the hoses & swap the coolant pipes on the bench. The top oil pipe can be disconnected at the turbo and very gently (usual disclaimers apply here) moved out of the way to allow the turbo to be removed. Don't forget the lower one.
Would advise you to have new studs and bolts available, also coolant banjo bolts (mine were badly corroded).
A100E6341S Banjo
A100E6342S Gasket
A100E6167S Stud
A100E6382S Nut
91 Lotus Elan SE Turbo
07 Alfa Spider 939
cliff
Postby paulsmithmk » Fri 21.09.2012, 20:59
cliff wrote:Piper removed the my old downpipe, so I don't really know what is involved in that apart from a lot of swearing.
A100E6341S Banjo
A100E6342S Gasket
A100E6167S Stud
A100E6382S Nut
many thanks - fancy a trip to Milton Keynes?!!! :D
S2 Number 640
paulsmithmk
Postby Steve A » Mon 01.10.2012, 11:56
:-D ordered mine today :bananasex:
couldn't bring myself to put the big heavy lump back on :wink:
Postby HJ2 » Mon 01.10.2012, 12:11
Ha!
That's the same reason i ordered an placed mine :-)
Postby TrevorB » Mon 01.10.2012, 14:25
Any thoughts on whether this downpipe may help with resolving my current problem as in my thread under Fault Code 33 ?
Trevor
HiSpec front brakes
PNM rear brakes
Aluminium radiator
Closed Loop conversion
Kilimanjaro chip
Wannabe Princess
Postby paulsmithmk » Mon 01.10.2012, 16:49
The heat shield is an issue and my garage is having to find a new way of attaching it so I think this needs further development. Once job is done I will update here...
S2 Number 640
paulsmithmk
Postby HJ2 » Mon 01.10.2012, 18:19
Mine is perfect in position (The top shield that is...)
Postby HJ2 » Mon 01.10.2012, 18:21
TrevorB wrote:Any thoughts on whether this downpipe may help with resolving my current problem as in my thread under Fault Code 33 ?
Trevor
I'm afraid it won't help Trevor
Postby Brit-Car-Nut » Mon 01.10.2012, 19:48
HJ2 wrote:Mine is perfect in position (The top shield that is...)
HJ: Where did you attach the shield to? The lower nuts for the shield are not on the pipe. Are you just using the top bolt?
What about the shield between the pipe and the engine?
Postby HJ2 » Mon 01.10.2012, 19:59
I use the top bolt and the one on the side. I made a bracket from a strip of stainless. It uses the existing hole in the heat shield and the other end goes to the bolt of the PAS pump.
2 out of 3... not bad! :D
I have no shield between pipe and engine. The distance is greater than to the front clam shell. Also the clam shell and bonnet are close and fiberglass, so i wanted to protect mainly that part. The biggest source of heat radiation below that is the cast iron housing of the pre-cat. This radiates long after you used the turbo! The piper pipe won't hold the heat as the cast iron lump so I'll take my chances. Also is the diameter of the piper a lot smaller than the pre-cat, so he radiation needs to travel further before it sees something.
I would not bother to mount the old shields back as they are custom made for the pre-cat housing. A dedicated, custom made part would be a better option if you really want to shield the lower part.
My 2 cents anyway :bonk:
Postby Brit-Car-Nut » Mon 01.10.2012, 20:02
Thanks. Also getting the pipe coated will also help heat control.
Just thought I would get the questions out there.
Postby paulsmithmk » Mon 01.10.2012, 20:07
HJ2 wrote:I use the top bolt and the one on the side. I made a bracket from a strip of stainless. It uses the existing hole in the heatshield and the other end goes to the bolt of the PAS pump.
I have no shield between pipe and engine. The distance is greater than to the front clamshell. Also the clamshell is fibreglass, so i wanted to protect mainly that part. The biggest source of heatradiation below that is the cast iron housing of the pre-cat. This radiates long after you used the turbo! The piper pipe won't hold the heat as the cast iron lump so i'll tak my chances. Also is the diameter of the piper a lot smaller than the pre-cat, so he radiaton needs to travel further before it sees something.
I would not bother to mount the old shields back as they are cusom made for the pre-cat housing. A dedicated, custom made part would be a better option if you realy want to shield the lower part.
Do think that Piper should have considered this tho as the job is becoming much more expensive than anticipated - for several reasons, one of which I wont go into unless I have to...!
S2 Number 640
paulsmithmk
Return to Exhaust
