HJ2 wrote:No Boost creep?
Lucky you!
Wait for winter before you smoke the cigar...
As the air gets colder, it is getting denser and chances of experiencing boost creep increase.
As the air gets cooler the more she stays in the garage!!!
Lucky you!
Swain Tech Coatings is the only company to offer a true insulating thermal barrier for exhaust parts. This external thermal barrier is applied approximately .012″ thick, has a white matte finish and does a tremendous job of keeping the heat inside of the pipes to improve scavenging and reduce under hood temperatures.
Cast Iron Manifold (4, 6 or 8 cyl.) $150 – 235
Turbo Charger Housing $90 – 125
O2 Housing $50 – $100
Pipes, Down Pipe, Crossover, Collector, etc. $40/foot approx.
ccb056 wrote:Either port the wastegate or restrict the flow through the exhaust.
surfboardfiller wrote:ccb056 wrote:Either port the wastegate or restrict the flow through the exhaust.
Why would you restrict the flow through the exhaust? The whole point of the down pipe is to de restrict the flow through the exhaust to improve performance.
The only thing I need to do now is alter the short section of pipe from the Piper down pipe to the exhaust,
I will be adding a flexi to take some of the strain and vibration away from the Piper down pipe, it's probably
why my exhaust sheared in the first place
it was over boosting like a
FFSpaulsmithmk wrote:OK so as you clever lot predicted got my first boost creep at the weekend - cold weather, revving through the gears and boom - fuel cut off, warning light on for about 30 seconds then back to normal and no repeat. So question - is porting the wastegate my only option?
wayne wrote:Sounds like the Piper downpipe is doing it's job ..... Increasing the airflow....
wayne wrote:How about getting Alan to review his mountain chip and raising the fuel cut off to more than 1 bar? would the stock injectors be able to deliver enough fuel? (or maybe upgrade fuel injectors to suit)?
wayne wrote:Seems a waste getting all of this extra airflow to spin the turbo to just vent it off in a different direction?
wayne wrote:Knowing nowt about turbochargers and airflow.......
rip wrote:wayne wrote:Sounds like the Piper downpipe is doing it's job ..... Increasing the airflow....
I agree. It is working too well.
