HJ2 wrote:Meanwhile, on the true Piper front:
I was thinking: Why not guide the wastegate gasses into a tube of a slightly larger diameter diameterthan the porthole, say 25mm. Then let it stick at a 90 deg. angle through the core flow (slightly flatten the tube where it goes through the core flow for less core resistance). after this section there is a lot more room to make a large radius and one could join the 2 flows at just a small angle at the end of the piper again. A bit of a hybrid between Piper and Knox ... The deflector can be ditched all together then.
Opinions please! (theory or evidence based )
dapinky wrote:I haven't done any recent elanscan runs where I go to redline in 3rd as I haven't been on track in it this year![]()
I see what you mean about the POTENTIAL improvement that a good downpipe may give, but what I'm really after is an answer to the $64,000 question "Will the downpipe give me a better driving experience than the system I already have" - and I believe that HJ is the only person to have gone from a Piper PCE to a Piper downpipe (but there may be others).
If i hadn't already got the PCE, i would be far more likely to get the downpipe, but having already bought what was the (then) best system availlable, will I see much of an improvement now for the money which needs to be spent.
It's not about top speed for me (and max power isn't at the red line anyway) - it's about the general 'pull' of the car.
dapinky wrote:I look forward to getting an elanscan run at WOT in 3rd gear to see what %age my wastegate is operating near the rev limit, now that ccb056 has shown me how to plot it to see what 'spare capacity' I may have (probably none!)
ccb056 wrote:You're assuming a lot of things in that statement and most of what you say is your own opinion. Let's post the data and let the people on the forum analyze it and draw their own conclusions.
surfboardfiller wrote:Results for:
Piper exhaust
Piper exhaust with Mountain chip
Piper exhaust & down pipe
Piper exhaust & down pipe with mountain chip
All on the same car, so I am testing the upgrades not the car.
surfboardfiller wrote:Piper exhaust
HJ2 wrote:I'll see if Peter agrees to have 2 tests on his car.
An unmodified Piper and a modified (if needed!)
