what are these little tabs?
Postby Lotussi » Mon 30.09.2019, 17:19
Hi All,
In the attempt to assemble an Elan engine from a box full of parts....
We stumble upon a lot of mysteries
Can any of you Elan experts help with identifying what these parts are?
And what is the purpose of them?
Thank you
Lotussi
Re: what are these little tabs?
Postby Simon_P » Tue 01.10.2019, 01:10
1 Could that be the spedo drive gear (can't get my bearings)
2 Do you mean the two spigots - they are for the vacumm hoses for the heating controls - there is a clear diagram of the connections in the worshop manual
Postby HJ2 » Tue 01.10.2019, 08:48
1. I think so as well. There should be a flat piece of metal sheet that goes into the groove of the speedo cable. The treaded hole is for the bolt that goes through the plate, holding everything together.
When you want to take the speedo gear out, loosen the bolt just a little, keep the plate attached and swing to the side, out of the groove.
2: Ah! here you are. The long hose in your other topic should go here :-)
Postby Lotussi » Tue 01.10.2019, 09:43
Hi Simon_P and HJ2,
Thank you;)
-I am looking through the manuals -can't seem to find the diagram ...
Tonight we will continue the puzzle!
will let you know the outcome
Lotussi
Postby HJ2 » Tue 01.10.2019, 10:54
Look for the vacuum overview in the manuals (no access right now, sorry!)
Postby Lotussi » Thu 10.10.2019, 13:21
Thank you for your answers,
We have manage to identify a lot of things
and got the engine to run- yeah ;)
but there are still some loose ends...
from my previous post of photos,
what was identified as the speedo drive gear,
there are some space for screws/ bolts
does anyone have a photo of that plate that goes here please??
Lotussi
Postby Simon_P » Thu 10.10.2019, 15:47
In the repairs section (above) there is a page on "transaxle oil change" the illustration is good.
Postby Lotussi » Wed 16.10.2019, 17:04
Thank you Simon P!
Lotussi
