Front spoiler rubber lip
Re: Front spoiler rubber lip
Postby niall » Mon 01.06.2020, 10:57
Simon, thanks for this. PM received and replied to. :D
niall
Postby Simon_P » Tue 02.06.2020, 09:37
Rubber lip Including Kitty donation
£20 without holes
£25 with Holes
£7 for screws and washers.
a. Rubber lip
1. Tuga2112 Paid / Delivered
2. Tuga2112 Paid / Delivered
3.
4.
5.
6.
7.
b.Rubber lip with holes
1. Niall (with fasteners) Paid 1/6
2. Rupert (with fasteners please)
3. NewLogik (with fasterners) Calculating postage to Canada
4. johnj (with fasteners please)
5. Portugal_lotus (with fasteners please)
6. Denny (with fasteners please) Paid 1/6
7. Geoff Paid 2/6
8. Fredjohn
9. Sheriff464.( Just one set of stainless fasteners please, if that would be possible?). Paid 1/6 + Kitty donation
10. Joe Roberts Paid 1/6
11.
12.
Postby Fredjohn » Tue 02.06.2020, 10:32
£20 without holes
£25 with Holes
a. Rubber lip
3.
4.
5.
6.
7.
7. Geoff Paid 2/6
8. Fredjohn Paid 2/6
11.
12.
Email sent. Thanks Simon
Elan S4 DHC 1969
Evora 2010
MB E250 CDi coupe 2013
Swift Sundance Lifestyle 500
Postby Simon_P » Sat 06.06.2020, 14:37
£20 without holes
£25 with Holes
a. Rubber lip
3.
4.
5.
6.
7.
1. Niall (with fasteners) Paid 1/6 collection due 8/6
3. NewLogik (with fasterners) Paid 9/6 sent 10/6
4. johnj (with fasteners please) Paid 3/6 collection due 8/6
6. Denny (with fasteners please) Paid 1/6 collection due 8/6
7. Geoff Paid 2/6 collection due 8/6
8. Fredjohn Paid 2/6 collection due 8/6
9. Sheriff464.( Just one set of stainless fasteners please, if that would be possible?). Paid 1/6 + Kitty donation Posted 6/6
10. Joe Roberts Paid 1/6 collection due 8/6
11. Lover (with Fastners) now with holes Paid 9/6
12.
Postby Lover » Tue 09.06.2020, 10:27
Hello
Please may i have a lip and screws ,fittings if its not too late to send request ,
Lip without holes please , please send me payment details have emailed seperatly ,
Many thanks ,
Roger
Lover
Postby Simon_P » Tue 09.06.2020, 12:07
All indicated packets collected by Hermes yesterday.
So finaly some instructions!
removing the old lip
1. Try to unscrew the screws
2. The rusty screws and washers will be stuck to the rubber so take pliers or Mole grips to the washers and screw heads and twist to unstick
3. be careful of the U nuts rotating as they will rip open the slot in the bumper.
Attaching the new rubber lip.
1. Without holes you are pretty much on your own! try pushing a srewdriver into the rubber to locate the hole.
2. With Holes I spent a day lining up the holes and checking that they are in the right place and give the right amount of slack or tension and the cutouts are in the correct place so that the lip sits correctly. Checked and cross checked on 2 cars assembled 7 times!
3. there are holes and slots in the bumper and the lip you may need to realign the U nut.
4. Starting from the centre put the screws in working to the sides - don't tighten them at this stage they should be very loose so that you can move the rubber.
5. when you get to the 3rd screw from the end do it up do that it is not lose but you can still position the rubber
6. The second screw from the end requires slight tensioning of the lip again do this up so that you can still position the rubber - leave the end screw for now
7. Go back and just pinch up all of the screws using the rear edge of the bumper and lip as a guide.
8 stand back and check that it is even and where it needs adjusting - make the adjustments
9 working from the center tighten the screws - don't over tighten them as this will deform the rubber - until you get to the 3rd one from the end..
10 between screws 2 and 3 requires a bit more attention hence the cutout and the slight tensioning of he rubber if you push the cutout fully back into the radius you should get the correct curve there should be a tight curve on screw 3 and this may make the washer stick out slightly if it is noticable and you are fussy like me replace it for a smaller washer - I have included some smaller diameter washers (free!)
11 once you have that sorted move on to the end - Mark the end of the bumper and cut to the desired length and shape. Sand the edges with 120 grit to give them a slight radius.
12 do up the end screw.
13 stand back and admire your handywork with an LEC cup of tea and make any final adjustments.
Postby Tuga2112 » Wed 10.06.2020, 06:00
Simon_P wrote:All indicated packets collected by Hermes yesterday.
i may make a video on this, easy and quick youtube views for my channel :smt043
a shame that the car is out of the garage and my brother's alfa 156 is there for suspension diagnosis, if id seen this 3/4 days ago i could have very easily recorded footage :(
1991 elan se
1991 elan se project
91 MR2 Turbo (import) project
94 Celica GT4 (Import)
94 4Runner
98 Celica SR
Postby Fredjohn » Thu 11.06.2020, 12:38
Simon
Lip received today. Many thanks for your efforts with this.
Elan S4 DHC 1969
Evora 2010
Postby Denny » Fri 12.06.2020, 17:50
Simon
Lip received safely.
Many thanks.
Red 1990 SE 24,800 miles - Bought 2020
Denny
Postby niall » Mon 15.06.2020, 21:11
Simon, Lip and fixing kit safely received. Many thanks for organising this.
niall
Postby Simon_P » Fri 19.06.2020, 14:30
£20 without holes
£25 with Holes
a. Rubber lip
3.
4.
5.
6.
7.
2. Rupert (with fasteners please) Paid 19/6 collection due 20/6
12.
13.
14.
15.
Any more for any more?
Postby RonR » Fri 19.06.2020, 16:49
£20 without holes
£25 with Holes
a. Rubber lip
3.
4.
5.
6.
7.
12. RonR (holes but no fasteners thanks)
13.
14.
15.
Postby Kzawilin » Sun 21.06.2020, 14:21
RonR wrote:Rubber lip Including Kitty donation
£20 without holes
£25 with Holes
a. Rubber lip
3.
4.
5.
6.
7.
13. Kzawilin (holes, no fasteners,cheers)
14.
15.
White, 1991 Lotus ELAN SE.
Oxford.
Kzawilin
Postby Lotussi » Tue 29.09.2020, 12:10
Hi there,
Have not been on line for a while...
Can I still order?
Lotussi
Postby robro » Wed 30.09.2020, 11:22
Brand new owner. Is this offer still open please?
robro
Postby Simon_P » Fri 02.10.2020, 16:48
Yes, what would you like?
Postby GeoffSmith » Fri 02.10.2020, 17:01
Simon, I've just approved robro's post so you may not have seen it.
Postby robro » Mon 05.10.2020, 09:51
I'd like a predrilled spoiler lip with fixings please
robro
Postby Simon_P » Tue 06.10.2020, 07:18
OK - I've got both of them.
I'm a bit busy lately - should get to it at the weekend. My PM is also full so I will also sort that out at the same time.
Postby robro » Tue 06.10.2020, 11:25
Thanks Simon. I actually sent you an email asking for payment arrangements, I'm not in a hurry.
robro
