HJ2 wrote:What is the latest insight on replacement parts ?
I think the answer to your question is yes; both + and - are supplied through the plug. From the plug follow the wire up to the top part of the frame where ist is grounded with a small screw.HJ2 wrote:Indeed. Should there be galvanic contact on the negative pole in the fan connector?
If so, I can make a temp. connection to check...
GeoffSmith - Tue 16.03.2021, 20:33 wrote:Or bad earth.
HJ2 wrote:So... I had 2 problems with 2 cars with at least 2 fans!
1.
On my own car, both fans did not operate anymore. Fan switch worked, fuses OK, Relais OK, Wiring OK, but ground of both fans was not connected to chassis properly apparently.
Simon, you were spot on!
Users browsing this forum: AhrefsBot and 4 guests
