racerstev wrote:Be careful with copper. To make it work well it needs a O Ring around the bore, a receiver for the O Ring in the head will make it a very very strong seal.
bobbrown wrote:racerstev wrote:Be careful with copper. To make it work well it needs a O Ring around the bore, a receiver for the O Ring in the head will make it a very very strong seal.
There is a UK company that makes copper gaskets that do not need the block and/or the head machined to accept a wire insert see ferriday as they have their own sealing rings but again head/block finish has to be correct with any of the MLS or copper options.
racerstev wrote:Wow, they ARE nice gaskets, things have come a long way since I tryed this. They seem to cover
all the problem area's I had, a real fire ring rather then a O Ring and viton seals for the oil
galley. I guess the newer sealants cover any problems with coolant seep.
A little pricey to start at $240 but a good plan B for sure!
I've seen the MLS gaskets hold over 1400hp on a 4 clyinder Chysler engine with no failures.
My own setup held 600 WHP agein with no issues on the same engine. This is why I'd rather
go with them if possable.
Steve Lockett
Specky wrote:I know he did have engine issues.
Specky wrote:There's only a few after Market head gaskets I know about and all have failed, but as to why, who knows.
racerstev wrote:Ferriday wrote back and said they would be happy to make gaskets for us but added that they are
really made more for race cars then street cars. They really stressed how perfict the mating surfaces had to be
to get a good seal. I'm leaning now towards plan C, O ringing the head or the block and using a stock or aftermarket
gasket. For those just replacing a gasket with out a full overhaul O ringing the head seems like the way to go.
Like I noted earlier in this thread, stock gaskets with O Rings should hold around 400hp. It's important to
have a good tune on the engine though, detonation will blow any gasket..
