bobbrown wrote:Bad news
You will need more than a set of rings if the bores are damaged.
Not sure what you mean by fit new sleeve as the bores are not sleeved to correct any damage in the bores you need to rebore to the next available size.
This can not be done with out first getting a set of pistons and rings as they are graded, standard pistons are in three sizes 80.0/80.01, 80.011/80.02 and 80.021/80.03 no doubt the oversize ones follow the same pattern available in + 0.5 and + 1.0 mm and it is normal to bore to the piston actual size.
tigerdog wrote:This could have been causedif a 3 bar MAP sensor had been fitted without also changing the injectors and other components to compensate. As your Elanscan posted elsewhere shows signs of this being the case, please check this out before restarting your rebuilt engine.
