Specky wrote:Just looked at the pictures on my phone, two questions spring to mind...
Is the new piston oversized and what's the weight difference to the others.
I can't see the markings on the head, cos it's blurred on the Afore mentioned phone.
PECKHS wrote:been doing some thinking, pls correct me if i'm wrong.
the m100 is using an isuzu engine, and if i'm not wrong it is the 4XE1W. i googled the engine model and the results i got was quite fascinating. some of the isuzu sites also linked the engine to the lotus elan.
so, if that is right, the should mean that parts applicable to the 4XE1W engine will be suitable for our m100?
bobbrown wrote:PECKHS wrote:been doing some thinking, pls correct me if i'm wrong.
You have to be careful as there are two versions a naturally aspirated and a turbo version and not all the parts are interchangeable this includes things like the block,pistons, cam shafts and head gaskets to name a few.
The codes Lotus used were 4XE1-M for the naturally aspirated and 4XE1-MT for the Turbo engine.
I still think the ebay engine was a reasonable option as it gives you so many more parts, TPS for example.
As far as piston 1 is concerned that is not detonation but a foreign object has been in there at some point and there should also be marks on the head it may be the reason why piston 4 was changed. Have a look at the head as if number 4 is badly marked then that is almost certainly what has happened.
The B on the piston indicates they are grade B and are 79.953 to 79.962 mm diameter the one marked AX is 79.945 to 79.959 in diameternot in it's self a major problem but I would check the weight as they should all be with in 10g of each other that complete assembley piston, rings and rods which isn't a lot.
PECKHS wrote:as racestev has indicated, i also suspect the engine has sat around for some time thus the rust in the bore. however, the rust is on the surface and has not corroded into the metal
i've taken a bet and ordered the piston rings from rockautos, hopefully they will fit. if not, i would be considering to change to oversized piston and rings. as indicated, a replacement engine will be the last resort
tks evrybody for their advise
davidh wrote:Hi Peck
Do you know that there is an Elan se available to buy for scrap in Singapore with a sound engine.
Call me if you need the details, I know the owner well
.so why we talk about you buying my engine or the whole car
PECKHS wrote:Piston rings from rockautos will reach Wednesday. Guess we'll know how they fit by this week.
