geoffsmith wrote:Pete, '93 Firebird if you can find one I'm afraid. Not that many cars with pop ups and it looks like Lotus used a part available from the US.
Doug, are they very common in the US?
Doug wrote:'93 Firebirds should be present in the junk heap already and decently common too. Wonder if some magician can find the GM part number for a 93 Firebird module and then maybe we can find other sources ??
petestubbs wrote:So with the engine running the O/S pod strains to move 2 inches with the engine off it comes up completely
geoffsmith wrote:That's quite possible Pete. You have about 14V available when the engine is running and 12V (or less if you keep activating the headlamps) when off. There is therefore more oomph available when the engine is running.
I guess your alternator problems must be causing a drain when the engine is running. What does your voltmeter (probably the only gauge that's accurate on my car) read when engine off & on?
petestubbs wrote:Geoff, Doug,
Found a firebird!
Ebay US version;
http://cgi.ebay.com/ebaymotors/ws/eBayI ... 31303&rd=1
Cost me $10 + $10 postage - cheaper than the £104 + postage that Bell & Colvill wanted!
Lets hope it works.
Thanks for the information.
Pete.
