Monty wrote:Neil, i`d be surprised if it was that as the fuel cap should be a tight seal, i`ve had the recess on mine fill up with water and had no ill effects![]()
Enright wrote:No, I'm sure it got in through there - you could see a wet trail leading down the inside of the neck of the fuel filler.
My fuel filler cap has a crack in it, but even if it didn't I think it must incorporate a breather somewhere or the fuel tank would implode as the petrol got sucked out. The injector cleaner sounds worth a go, and I'll try to pump out the rest tomorrow.
Galsia wrote:Kinda related question here. What is the best way to unblock the drain pipe near the fuel filler cap? Mine is blocked and I keep finding water in there am worried about water getting into the fuel system. I've got a bit of sponge in at the moment.
Thanks.
paza1 wrote:The top of the fuel cap does seem to be more intricately made than necessary if there is no breather valve of some sort. Would be interesting to get a definitive answer on this.
Mark
Enright wrote:
Last night the weather was OK, so I removed the fuel pump out of the tank in order to empty it. I was surprised how much water was still in there - it's really obvious when to look at it how it separates.
Enright wrote:You simply can't pump out that much fluid and not replace it with anything - the tank would implode.
