Loud "cracking" noise from door
Postby Gareth » Mon 23.02.2009, 15:43
Every time I open the passenger' door I hear a loud "crack"
Upon investigation (as Sherlock Homes would say) it appear that this is coming from
the junction of the front wing panel and the front leading edge of the door.
It looks like the edge of the door panel should overlap the edge of the wing when opening the door but on
my car it's actually hitting the end of the wing which causes the noise.
I can also see this as the paint finish has rubbed off at this point
Any suggestions for an easy "idiot proof" solution?
Gareth
Gareth
Re: Loud "cracking" noise from door
Postby rip » Mon 23.02.2009, 15:50
Wait until the weather changes:- the panels move a little due to the heat (honest).
Can you adjust your doors or clamshell at all? Just a little may be enough.
Postby Gareth » Mon 23.02.2009, 16:20
rip wrote:Wait until the weather changes:- the panels move a little due to the heat (honest).
Unfortunately the Science of car mechanics/bodywork are all a mystery to me
How is the door or clamshell adjusted ?
"idiot proof" instructions appreciated :roll:
Gareth
Gareth
Postby dapinky » Mon 23.02.2009, 16:34
Just being really pessimistic here (and i hope your's is the easier solution).....
...when this started on the red one, i was expecting to just adjust the door/'A' panel gaps, but found that the reason for the original door movement was due to a collapsing rusted lower door hinge.
This is a replacement door situation, so i hope yours is still sound and just needs the 'simple' adjustment.
Postby Gordon » Mon 23.02.2009, 17:01
dapinky wrote:...i was expecting to just adjust the door/'A' panel gaps, but found that the reason for the original door movement was due to a collapsing rusted lower door hinge.
That's exactly what I had - the scrap door is still in my back garden...
Scrap door - with pictures
No doubt at all that in the event of a side impact, the door strength would be seriously compromised... :(
Gordon
1990 M100, Calypso Red
2005 Vectra C....
Gordon
Postby RichardK » Mon 23.02.2009, 18:12
I have the same problem on my passenger door too - but only when it is really sunny. I am pretty sure my adjustment is not due to rust penetration the car is a garage queen with bugger all rust anywhere except the rear disks..... can anyone point me in the right direction as to which bolts/screws/washers to adjust first.
Cheers ( and apologies for the slight highjack of the thread)
Richard
RichardK
Postby Gordon » Mon 23.02.2009, 18:15
Very quick test for rust (as it's not very obvious until you dig at it..)
Open the door about half way, and see if there is any lift/drop in the door (as in checking for hinge wear). The hinge pins themselves are quite over-engineered, and dont seem prone to wear - if there is any lift/drop in the door - it's probably a rusty door hinge...
Gordon.
2005 Vectra C....
Gordon
Postby Gareth » Mon 23.02.2009, 19:02
RichardK wrote:I have the same problem on my passenger door too - but only when it is really sunny. I am pretty sure my adjustment is not due to rust penetration the car is a garage queen with bugger all rust anywhere except the rear disks..... can anyone point me in the right direction as to which bolts/screws/washers to adjust first.
Richard
Ditto above
Same request
Gareth
Gareth
Postby Gareth » Mon 23.02.2009, 19:28
Gordon wrote:Very quick test for rust (as it's not very obvious until you dig at it..)
Gordon.
Just checked as suggested : no lift/drop
But guess what : put car back in Garage earlier : noise has now stopped : could it be that temperature
has an impact? (as suggested by Richard K & Rip)
Still request "idiot proof" tips on adjusting door
Gareth
Gareth
Postby paulwatkins » Mon 23.02.2009, 19:44
It sounds as though the panel between the door and front wheel has moved slightly.
You need to reposition it and then tighten the bolts (behind the panel) that hold it in place. You get to the bolts by opening the door and using a socket on a flexi-drive.
paulwatkins
Postby John_W » Mon 23.02.2009, 20:44
Gareth, Richard,
Mine started doing this at the Hethel 60th in September. I gave the A panel a gentle shove in and it stopped.
For a proper solution you'll probably have to tighten the bolts or shim it somehow. See the attached image.
Postby Exbury » Mon 23.02.2009, 23:10
Ditto with mine, I just have not got around to fixing it yet. There should be bolt heads visible when you open the door at the bottom of the wing on the inside, need a flexible driver or bend a cheap spanner to fit, its a little tricky but is possible to get in. The next question will be - do the screws bite and clamp the wing in the right position!
Exbury
Postby Gordon » Mon 23.02.2009, 23:45
The two bolts securing the lower edge of the panel to the sill tap into "rawl nuts".
Rawl Nuts
These are rubber, with a brass insert, and they expand and clamp as the bolt is tigtened.
Lotus use them alot, but the rubber gives up with time, and they stop clamping...
The remains of an expired rawl nut can be a swine to get out aswell, as the brass insert will be bound onto the threads of the rusty bolt, but parted company with the remains of the rubber housing...
Incidently, the two sill bolts on mine have a clamping plate bridging between the two, which seems like an excellent idea..
Gordon.
2005 Vectra C....
Gordon
Postby martin_bailey_1 » Tue 24.02.2009, 00:18
Gareth,
If it helps, here's a photo of the (L/H) hinge aperture on my car:
You can see one of the bottom 'A' panel mounting bolts at the right hand end of the photo (the one with the large washer under the bolt head.)
Also visible, are the various door hinge mounting bolts...... you may be able to adjust the door slightly, but If it were me I'd definitely be having a go at the 'A' panel first ..... the bolts are slightly more awkward to access, but the panel's much lighter and easier to manhandle :!:
Good luck,
Martin,
martin_bailey_1
Postby Gareth » Tue 24.02.2009, 09:12
Thanks to all for the advice/tips/diagrams/photographs
I'm off to buy a sledgehammer to undo the screws/nuts
Gareth
Gareth
Postby kurgen » Tue 24.02.2009, 13:49
I have the same problem. Cure? In my case a smear of vaseline on the wing, the door slides over it nice and quite now...
regards
dave
kurgen
Postby ShaunM » Sat 14.03.2009, 19:55
I had the same problem and did the vaseline trick (kurgen) and also the a-panel shove (John_W) to temporarily fix this problem. It has scraped a little paint off the A-Panel, but slides over okay now.
Will have a go at the bolts (nice one John_W) and adjust when it's nice and warm - a good sunday morning job, with the "treat" of an afternoon drive as reward :lol:
ShaunM
Return to Doors and Windows
