Wont start!
Wont start!
Postby FYN » Mon 27.04.2009, 21:34
Over the past two months, i have rebuilt engine having replaced piston rings, shells and engine gaskets. After finally getting everything back together the engine will turn over but will not fire, before rebuild i could hear the fuel pump running when i turned the key prior to starting, now i cannot hear the fuel pump, is there an in line fuse for the pump or why does there appear to be no power going to the pump? Should the engine management light come on initially with the ignition lights?
The fuel inertia shut off has been tried in both positions, this has made no difference and we have also bridged into the wires for the fuel pump and managed to get it to run, again it has made no difference.
any advice appreciated
FYN
FYN
Re: Wont start!
Postby Paul.P » Mon 27.04.2009, 22:10
FYN wrote: Should the engine management light come on initially with the ignition lights? FYN
Definitely !, have you got an alarm or immobilser ?
Re: Wont start!
Postby FYN » Mon 27.04.2009, 22:20
Paul
Immobiliser was stripped out of car last year, new toad system still to be fitted.
Alarm system at present is switched off.
FYN
FYN
Re: Wont start!
Postby Specky » Mon 27.04.2009, 22:25
Have you checked............... the fuel relay,fuses and the three connectors just in front of the expansion tank for security of attachment.
The engine light should stay on until the engine fires into life...IIRC the light does blip when the starter draws the initial surge of power thou...
Re: Wont start!
Postby HJ2 » Tue 28.04.2009, 08:16
Or perhaps... Inertia fuel cut switch (or what's it called) behind the seat?
Re: Wont start!
Postby dapinky » Tue 28.04.2009, 17:55
FYN,
If I may indulge you with the information on my post this one, here, there is a simple test you can perform to show if the injectors are opening.
This leads on from Speckys advice about the '3 plugs' by the water expansion bottle (the ones in the green circle in the photo)...
Re: Wont start!
Postby Doug » Tue 28.04.2009, 19:51
yes, the fuel pump fuse, relay, and inertia switch are the start point if you can't hear the pump run each time you turn on the ignition. They're all behind the left seat speaker enclosure in Federal Elans; I think they are still on the left for you too.
Re: Wont start!
Postby saska » Tue 28.04.2009, 20:13
FYN wrote:Paul
Very primitive but first things first; have you definitely got spark to the plugs?
Tony
adw (at) saska.co.uk
saska
Re: Wont start!
Postby The Ref » Tue 28.04.2009, 21:43
saska wrote:
FYN wrote:Paul
No :wink: the first thing is do you have fuel :twisted:
There are 3 types of people in the world. Those that can add up and those that can't
The Ref
Location: The "pools" HUFC must win a game some day soon
Re: Wont start!
Postby saska » Tue 28.04.2009, 21:55
The Ref wrote:
saska wrote:[
<G> Neither works without the other. Problems are a process of elimination. Logic says eliminate the simple to check ones first.
You can test spark with a screwdriver, whereas testing the Elan's fuel injection system is somewhat more complex.
Check the simple things first.
Tony
saska
Re: Wont start!
Postby FYN » Tue 28.04.2009, 22:21
Whilst checking on the diagnostic plug, bridging out the black and black and white wire the engine management light does not illuminate this is the same problem as when the ignition is switched on, no engine management light comes on.
Where does this get its feed from as all the fuses appear to be ok?
FYN
FYN
Re: Wont start!
Postby dapinky » Wed 29.04.2009, 11:54
saska wrote: Problems are a process of elimination. Logic says eliminate the simple to check ones first.
To find any specific fault is a process of elimination - after all, logic dictates that it is always the last thing you test, which is faulty!
There are 3 main reasons why an engine wont fire.....
1) No Spark
2) No fuel
3) Mechanical failure (including no compression)
1) & 2) can be tested for by removing a sparkplug after turning over the engine on the key - the plug should be damp from petrol (or at least smell of vapour!) - then by putting the HT lead back on the plug and grounding the body of the plug to earth (resting on top of the engine is good), turn the key and you should see a spark jump across the plug gap.
This will not show a deficiency in performance of any particular component, but may show up any obvious route of enquiry.
FYN,
I know nothing of the circuit for the engine light, but do you remember if it was illuminating before the current fault? - there are fuses for the ECU which may have a bearing on the light (but an expert will be able to give better advice).
Re: Wont start!
Postby Specky » Wed 29.04.2009, 18:44
Did the car run after the immobilizer was removed...
Re: Wont start!
Postby FYN » Wed 29.04.2009, 23:24
Before the car was taken apart, the engine management light did operate when i turned the ignition on, the cad did run up until we decided to rebuild the engine, it started no bother after letting the fuel pump run, but now the fuel pump does not run at all, and there is no engine management light. the immobilizer was removed two months prior to the car being taken off the road for engine rebuild.
FYN
FYN
Re: Wont start!
Postby Specky » Thu 30.04.2009, 19:20
is the engine properly earthed after the refit...A quick con check may help...
Have you checked the wires where the immobilizer was removed and also con checked the ignition barrel
was the ECU disconnected for the engine work...
Have you checked all the fuses, relays etc...
