Window parts - no longer available
Postby Dynoguy » Mon 01.06.2009, 19:42
I am looking for the rollers that go into the white rectagular slides that go up and down for the windows. For some reason mine are missing. I bought the new slides from Dave Bean, but they do not have the rollers. Anyone can help?
Dynoguy
Re: Window parts - no longer available
Postby esprit888 » Mon 01.06.2009, 20:03
I'm placing an order today so i will let you know if they are available. The problem is, as you can tell from the posts, Lotus changed the requirements for these windows numerous times, from three sliders to four, to three of one type and one of another, to 10 vertical sleeves to 10 horizontal rollers, to three rollers to four, and on and on. Look as though they were winging it way after the cars left the factory and it may be that we can experiment just as well as they can until we get the right mix (and from the fact that they continue to be a pain in the A** its obvious they never did!)
Dynoguy wrote:I am looking for the rollers that go into the white rectagular slides that go up and down for the windows. For some reason mine are missing. I bought the new slides from Dave Bean, but they do not have the rollers. Anyone can help?
esprit888
Postby Dynoguy » Mon 01.06.2009, 22:46
MMM BRG is good
Thinking I may just make some from delrin, the ones in there were squshy, but I cant see why some graphite impregnated delrin would'nt make them slide like greased butter
Dynoguy
Postby bobbrown » Mon 01.06.2009, 23:45
Delrin may be a little hard, I think they are supposed to be flexible, if they are too ridged you could break the glass or snap the little beggars off.
I did think of some nylon or polyurethane tubing cut to length, I have my passengers window to fix at some point in the not too distant future, another little job I’ve putting it off.
Pacific Blue N/A
Postby esprit888 » Tue 02.06.2009, 23:12
Placed an order with Williams of Bristol for the window slider parts. The following is the result.
6 X A100B0699F - SLIDER BLOCK (not available)
2 X A100B1097F - SLIDER BLOCK (available so i have increased this to 8 as it appears to replace A100B0699F)
10 X A100B1089 - ROLLER, SLIDER BLOCK (will confirm availability end of the week)
2 X A100B6271S - BUTTERFLY CLIP (available)
2 X A100B6151H - CLIP, LOCKING BUTTON (available)
1 X A100B6211S - SLIDE (available)
1 X A100B6210S - SLIDE (available)
esprit888
Postby BFG in the BRG » Wed 03.06.2009, 13:43
I bought some lengths of nylon rod of about the correct diameter with the intention of replacing the rollers - but decided to use the old ones in the end - one option might be to cut odd the correct length, and if still concerned about the hardness - drill a hole and then fill with sikaflex to make it squishey - might work - if you want a length of nylon rod let me know I can pop it in the post - donno if you can get nylon tubing.
Alas soon to be Elan-less
BFG in the BRG
Postby Ekapol » Thu 04.06.2009, 11:39
I've just called DBE. The rollers are out of stock, and possibly will be not available through them again.
I would need to go to the hardware store for some usable replacements.
Ekapol
Postby esprit888 » Thu 04.06.2009, 20:54
Still no answer from my order, so i have sourced the thickwall fibre reinforced clear nylon plastic tubing and will experiment with different types of filler (sikaflex is probably the least flexible of the silicon family)
Ekapol wrote:I've just called DBE. The rollers are out of stock, and possibly will be not available through them again.
esprit888
Postby esprit888 » Thu 04.06.2009, 23:18
Ok, just got the call and the 10 rollers (A100B1089K) are no longer available so we are on our own for those plus the A100B0699F - SLIDER BLOCKS, which are also unobtanium from Lotus. This does not bode well for the future of any window repairs as these, along with the motors themselves, are the main wear items. Time to get the A/C topped up and stop playing with the window switches when its hot (like today, fourth day in a row its over 32 celsius)
esprit888 wrote:Still no answer from my order, so i have sourced the thickwall fibre reinforced clear nylon plastic tubing and will experiment with different types of filler (sikaflex is probably the least flexible of the silicon family)
esprit888
Postby bobbrown » Thu 04.06.2009, 23:27
If some one can come up with the dimensions of the rollers I can make a batch up using say Nylatron
Pacific Blue N/A
Postby esprit888 » Fri 05.06.2009, 04:23
Bob,
As soon as i get my sliders in the mail i will strip it down taking many pics & shoot you the dimensions. I am all for being a 'test dummy' if needed :lol:
bobbrown wrote:If some one can come up with the dimensions of the rollers I can make a batch up using say Nylatron
esprit888
Postby surfboardfiller » Mon 15.06.2009, 13:14
I think I have a spare set if you want to make copies. :wink:
surfboardfiller
Postby Specky » Sun 21.02.2010, 15:37
Bob, Bob, Bob,
Did you you take this challenge up Mister?
TWR was asking... :poke:........... OK then,he wasn't..... but I thought I'd just ask.... :wink:
Postby bobbrown » Sun 21.02.2010, 17:25
still waiting on someone coming up with the dimensions
Pacific Blue N/A
Postby Specky » Sun 21.02.2010, 17:52
You should have said..... :-D
I'll have a look and see what bits I've got...
Postby lotusgirlmarie » Sun 21.02.2010, 18:15
Ekapol was missing his rollers as well. We just used thick wall nylon tubing I believe in a 1/2" diameter. Can't remember the exact size at the mo'. Worked a treat thought and we just cut to lenght.
lotusgirlmarie
Goddess
Postby ab2cv » Tue 23.02.2010, 17:17
I have two windows in need of repair so very interested in this thread with regards to replacement parts. Doors will be getting stripped and rebuilt (hopefully) in time for Malvern........
Yellow Esprit GT3
ab2cv
Wot's the latest on the rollers?
Postby tigerdog » Tue 02.03.2010, 00:44
I'm going to be tearing into Smaug's doors as well since one of my windows is permanently down at the moment. Bob, did anyone get you the dimensions you require? You're going to have a full-time job making M100 bits before too long! :-D
Re: Wot's the latest on the rollers?
Postby bobbrown » Tue 02.03.2010, 10:29
tigerdog wrote:I'm going to be tearing into Smaug's doors as well since one of my windows is permanently down at the moment. Bob, did anyone get you the dimensions you require? You're going to have a full-time job making M100 bits before too long! :-D
In simple terms no, one of the problems with the rollers is they get squished and are usually out of shape so they may be difficult to get exact sizes but close enough will have to do.
Pacific Blue N/A
Bob, meet Phil. Phil, Bob...
Postby tigerdog » Tue 02.03.2010, 15:47
surfboardfiller wrote:I think I have a spare set if you want to make copies. :wink:
Or maybe he doesn't have a spare set after all?
