Oil Pressure
Oil Pressure
Postby Andy_J » Sun 14.03.2010, 20:51
Started to connect up some of the dials on the red SE today, When I connected up the oil pressure guage, I got no reading on it with the engine running.
Instrument cluster red oil warning light is off and looks like there is oil reaching the top of the engine? Can't find a reference to the pressure transducer in the workshop manual. Can anyone advise of the location of the transducer or any other ideas why I have no oil pressure on the pressure guage?
90H BRG SE 48,000 Miles
Andy_J
Re: Oil Pressure
Postby GeoffSmith » Sun 14.03.2010, 21:09
Cunningly concealed:
Re: Oil Pressure
Postby Andy_J » Sun 14.03.2010, 23:13
thanks geoff,
another easy to get to bit on the elan...not.....think sorting that can wait till next weekend
Andy_J
Re: Oil Pressure
Postby GeoffSmith » Sun 14.03.2010, 23:20
Looks like the Elan's G-spot - a bugger to find but well worth it!
Re: Oil Pressure
Postby Andy_J » Mon 17.05.2010, 22:13
Has anyone got a picture of the back of the engine, I have tried following the diagram Geoff has posted and i still can find the transducer
Andy
Andy_J
Re: Oil Pressure
Postby dapinky » Mon 17.05.2010, 22:32
For what it's worth, here's one......
The transducer is hidden behind the starter though :roll:
Down here
Re: Oil Pressure
Postby Andy_J » Mon 17.05.2010, 22:37
Thanks Dapinky, don't think I am any the wiser :roll:
I will try swining my hand around down by the starter
Andy_J
Re: Oil Pressure
Postby Andy_J » Tue 25.05.2010, 13:10
Managed to sort my problem this morning. after reading TJi's 'It started with a stero' minor project I realised the wiring was different on his oil guage to mine. Having swaped afew cables round I now have oil pressure showing on the guage :oops: :oops: :oops:
Andy_J
Re: Oil Pressure
Postby PECKHS » Thu 30.09.2010, 02:30
hi, i tried to find more information about the oil pressure transducer, but there seems to be a lack of information.
can i know what other cars have a similar oil pressure transducer? and whether i can get hold of one other than SJS auto? Rockauto maybe? same as impulse?
tks
Peck
PECKHS
Re: Oil Pressure
Postby lotusgirlmarie » Thu 30.09.2010, 03:19
Considerring the gauges are VDO...... As are the temp sensor, boost transducer, knock sensor, fuel sender....... Only the main cluster is Delco.
lotusgirlmarie
Goddess
Re: Oil Pressure
Postby PECKHS » Fri 01.10.2010, 02:28
lotusgirlmarie wrote:Considerring the gauges are VDO...... As are the temp sensor, boost transducer, knock sensor, fuel sender....... Only the main cluster is Delco.
sorry didn't quite get you.
the oil pressure transducer is a VDO item?
tks
PECKHS
Re: Oil Pressure
Postby GeoffSmith » Fri 01.10.2010, 05:39
I believe so as VDO seem to use a standard sensor/gauge combination (how sensible) but make sure you go for a 10 bar one to match the gauge, check the thread and make sure it will fit as it looks quite crowded behind the starter. Search e-Bay for "VDO oil pressure 10 bar"
Alternately, check out Rockauto | Isuzu | 1991 | Impulse RS | Electrical switch & relay | Oil pressure switch | STANDARD MOTOR PRODUCTS Part # PS342 With Gauge | - looks right but don't go for the ones listed with light as these are switches for the oil pressure warning light.
Re: Oil Pressure
Postby PECKHS » Sat 02.10.2010, 07:57
GeoffSmith wrote:I believe so as VDO seem to use a standard sensor/gauge combination (how sensible) but make sure you go for a 10 bar one to match the gauge, check the thread and make sure it will fit as it looks quite crowded behind the starter. Search e-Bay for "VDO oil pressure 10 bar"
hi geoff, somehow they doesn't look the same
this is from sjs for GBP70.49
and this is from rockauto for US$45.89
there's a lot of difference in the price, and i would definitely like to get the one from rockauto,but................
care to comment?
tks
PECKHS
Re: Oil Pressure
Postby GeoffSmith » Sat 02.10.2010, 11:02
Looks like the SJS one has the pressure transducer (for the gauge) and switch (for the warning light) in one unit so two connections. They're shown separate on the circuit diagrams but I haven't ventured into that dark grubby area before - can anyone with an engine in the conservatory confirm and preferably take a picture please?
Re: Oil Pressure
Postby saska » Sun 03.10.2010, 17:27
GeoffSmith wrote:Looks like the SJS one has the pressure transducer (for the gauge) and switch (for the warning light) in one unit so two connections. They're shown separate on the circuit diagrams but I haven't ventured into that dark grubby area before - can anyone with an engine in the conservatory confirm and preferably take a picture please?
I looked at spare S2 engine earlier today and it does have 2 connectors (screw-on nuts) like the SJ's one. Also worth noting the SJ's one has the proper Lotus part #
I'll take a photo of it next time I'm over there as that engine doesn't have starter in it so oil pressure sender is clearly visible. Wil see if I can get wire colours and any connector terminal info as well.
Think if it is a combined warning light/pressure transducer then it'll be important to wire the correct way round otherwise you may fry something (like the guage)
Tony
adw (at) saska.co.uk
saska
Re: Oil Pressure
Postby GeoffSmith » Sun 03.10.2010, 17:42
Thanks Tony. According to the WikiWiring, the gauge should be brown on white and the light .. should ..... be........ white on brown! :banghead:
Re: Oil Pressure
Postby PECKHS » Mon 04.10.2010, 02:24
tks. looks like i'll have to get the one from SJS then
cheers
Peck
PECKHS
Re: Oil Pressure
Postby saska » Mon 04.10.2010, 18:13
PECKHS wrote:tks. looks like i'll have to get the one from SJS then
cheers
Peckhs,
I'll attach some photos at end but this is almost certainly a VDO unit as LGM said earlier. I couldn't get a VDO part number off it as I didn't have time or want to remove it.
If you look HERE you can see that the unit has the same notch at top, 2 poles marked G and WK and is a combined pressure and low warning light switch. Nevertheless without a VDO part number I'd still suggest getting the SJs part.
The important point is that for our cars the wiring is as follows:
Terminal marked G == White / Brown stripe (Gauge)
Terminal marked WK == Brown / White stripe (Warning Light)
Edit: Going back to your original post which says the oil warning is off, then this suggests the transducer is working. Perhaps it might be a good idea to recheck the wiring at the gauge end to ensure you have it the right way around. Think I'd do this before forking out >£70 for the sender unit.
Below is photo of the wiring on a working gauge:
Tony
saska
Re: Oil Pressure
Postby GeoffSmith » Mon 04.10.2010, 19:42
More info:
As Marie suggested, there aren't many variations of VDO sensors. They all look like something like this:
There's quite a lot of information on boaty websites. All threads appear to be 1/8" x 27 NPTF. Some have low pressure switches (0.25 Bar for the 39/15) and some don't (0.8 Bar for the 39/02 & 39/03) - I would imagine 0.8 bar is OK. We need the common ground type but these are all insulated return, however the insulated return could simply be connected to the block. We do need the 10 Bar type however to amtch the gauge.
Re: Oil Pressure
Postby bobbrown » Tue 05.10.2010, 01:18
Geoff
Looks like the threads are not all 1/8 NPT as they also do a M10 version see link the 1/8 NPT is stamped 30/15 so I do not think it is that one so the chances are it is the metric one, 360-023 150psi /10 bar Metric M10 x 1 thread , I've aske them at the link above if it has a number on it like SJ's e.g. 30/9 as it is just a tad over half the price.
Pacific Blue N/A
