RayD wrote:Have you seen the damaged gasket yet Tony ... where has it failed?
tonny006 wrote:RayD wrote:Have you seen the damaged gasket yet Tony ... where has it failed?
Yes I have Ray,
It's got a piece missing between cylinders 3&4 but the rib between the other cylinders don't look good.
I will try and post some photos later.
Tony
racerstev wrote:We need to get a group buy together with Cometic. They will build us a nice multi layer steel gasket that will hold the power.
The last time I asked about one was 9 years ago, they needed a min 25 peices at $100 each at the time..
I found the stock gasket was good to low 400's with head studs before it started to fail. I tryed O rings and
copper gaskets at the time and had no luck with them. With O ring I was able to get about a dozen 1/4 pass's
before blowing a gasket at 500 wheel HP..
Steve
Steve
Monty wrote:WoW thats bad![]()
Just wondering if the head bolts had come lose![]()
Stock gasket should be up to the job, my last one was done about 3 years ago now
Enright wrote:I'm sure Costas had a copper one made for his Sh4rk, but I have no idea how feasible or cost effective this would be.
bobbrown wrote:If you mean indentations left in the head from the flame rings (the bit that sits around the gasket in way of the bores) then these need to be removed even when fitting a standard gasket. If you had indentations in the head from the flame rings when fitting the last gasket it may go some way to explain the failure this time.
