squealing cooling fans
Postby ppete100 » Mon 26.03.2012, 21:28
cooling fans started making a squealing noise lately, is there anyway to lubricate them or are they on their way out? :?
-pete
ppete100
Re: squealing cooling fans
Postby C3LOS » Mon 06.03.2017, 23:29
Hi, I noticed your question as I have a similar issue.
Did you work out a solution?
Carl
C3LOS
Postby Simon_P » Tue 07.03.2017, 00:32
Drill a very small hole in the tit on the backplate and syringe a couple of drops of thin oil in to lubricate the bearing.
Postby C3LOS » Tue 07.03.2017, 23:27
Thanks for the advice! Job for the weekend! Wish me luck
C3LOS
Postby Rambo » Wed 08.03.2017, 10:19
And after you've done that, and hopefully lost the squeak, remember to let your engine get hot and check that both fans kick in when the needle on the temp gauge is approx. at the 3/4 mark :wink:
Postby C3LOS » Wed 08.03.2017, 23:13
Will do Rambo...thanks for the advice
C3LOS
Postby C3LOS » Fri 17.03.2017, 20:58
Been busy doing Luther things, but got round to looking at this issue today, and to my surprise there was already a drilled hole in the tit of the casing....good because it's easy for me to just add the oil, the bad thing is that it was a problem prior to me getting the car!
Fingers crossed it will work
C3LOS
Postby C3LOS » Sun 19.03.2017, 22:41
Tried the oil suggestion today, and initallly the fan was quiet, however the last 30 seconds it started making a noise again...anymore thoughts LEC members?
C3LOS
Postby novacaine » Sun 19.03.2017, 22:50
Fit some new modern fans ;)
novacaine
Postby Simon_P » Mon 20.03.2017, 03:40
Yes, be patient. give it a couple more drops of light oil and work it by shorting the sender wire.
Old fans are Renault OEM or Kenlowe and balanced, new generic fans are Chinese and not balanced.
Postby C3LOS » Mon 20.03.2017, 22:01
Thanks...will be patient and try some more lube and see how it goes...if not SJ sell a replacement fan....not OEM by the looks of it....Strange is selling a second hander on ebay...OEM version but difficult to know if it's ok.
Thoughts?
C3LOS
Postby clemo » Tue 21.03.2017, 10:20
C3LOS wrote:Thanks......Strange is selling a second hander on ebay...OEM version but difficult to know if it's ok.
Thoughts?
DVB / Strange has not had the best reputation of recent .
Check Apollo or SurferPhill ( pm him only though)
clemo
Postby C3LOS » Tue 21.03.2017, 22:28
Thanks clemo
C3LOS
Postby Steve A » Wed 22.03.2017, 01:20
novacaine wrote:Fit some new modern fans ;)
:agree: Much better (and lighter)
Postby tigerdog » Sat 08.04.2017, 20:00
Simon_P wrote:Old fans are Renault OEM or Kenlowe and balanced
May have been balanced at one time, but Smaug vibrates like a, well, vibrator, when the fans come on. After 20 years of use, I wonder if the balance has gone out the window.
Postby Brit-Car-Nut » Sat 08.04.2017, 23:40
Federal fans are completely different from UK/ROW cars. The Fed fans are larger and all plastic.
From what I read, the plastic fan rarely has bearing issues and the outer metal case of the UK/ROW version will disintegrate in a few years while the plastic lasts a long time.
Doug: I would look at the fans closely to see if a blade has broken or picked up some road trash/tar which would throw it out of balance.
The fans are mounted to the SIR/radiator support using a grommet and a shouldered washer (washer with a distance tube attached) so they are never mounted directly to the radiator support system. Maybe one of the mounts has failed?...
Postby Simon_P » Sun 09.04.2017, 19:53
Plastic fans also used on S2 ( mine has one of each) are made by Kenlowe and the blades are not trimmed like the Chinese fans, and are balanced using small steel clips.
Postby C3LOS » Sun 09.04.2017, 20:56
I have finally made a decision and bought the fan from SJ. Plastic with metal plates for fitment purposes. Get it next week and will be fitting it asap.
Thanks for the help buys
C3LOS
Postby C3LOS » Mon 10.04.2017, 20:42
Just received my cooling fan from SJ and to my surprise it's the original OEM part! Happy days!
C3LOS
Postby C3LOS » Fri 19.05.2017, 22:49
Fan changed yesterday and all is well.
Checked the old fan off the car and as I expected the bearings were knackered and the fan when rotated was far from smooth.
Surprised it was still able to operate to be honest!
Here's to trouble free driving (for at least the summer!)
C3LOS
