Rubber Grommets for Radiator
Postby Monty » Fri 01.03.2013, 19:56
Found out my Alloy rad is leaking due to it being lose and can only assume the rubber grommits have popped out and now i need to remove the rad to have repaired.
So i require 2 upper rubber grommits that sit in the tops section of the chassis/crash structure were the rad spiggots would sit.
Or if anyone has dimension to the grommits that would be a big help too.
Re: Rubber Grommets for Radiator
Postby GeoffSmith » Fri 01.03.2013, 20:23
Here's one...
I've got an old rad in the garage so I can measure the ID if you want and you can estimate the OD from this picture:
Or you can buy 2 off A100K6016F from SJS for 81p each. :D
Postby Monty » Sat 02.03.2013, 19:04
Thanks for that Mr Smith, are those for the upper spiggots?
Checked on SJ`s site and its nearly a fiver for postage, i`ll ring them tomo`s.
Re: Rubber GrommEts for Radiator
Postby Peter_W » Thu 23.05.2013, 05:50
I just received in the mail from the fine folks at Dave Bean's 2 each of the "Grommet, radiator mounting, top - A100K6016F" and the "Bush, radiator mounting, bottom - A100K6017F" - pics below. Having just removed my radiator, the top grommets were a bodge job from the shop that built me a new radiator ~12 years ago so I didn't have a reference for the size of the proper grommets except for remembering seeing the picture Geoff linked in this thread - the ones I received in the mail seemed way too small from what I remembered seeing in this thread. Having spent way too much frustrating time unsuccessfully looking for this thread using LECs search function, I found it again after realizing that you guys across the pond have been spelling grommet as a cross between its "proper" spelling and Wallace's companion :-D :poke: To my relief the sizes match as I forgot that you are all in the process of "metrication" and that the ruler in Geoff's liked picture was in metric denominations :bonk:
Peter_W
Postby GeoffSmith » Thu 23.05.2013, 11:23
Peter_W wrote:Having spent way too much frustrating time unsuccessfully looking for this thread using LECs search function, I found it again after realizing that you guys across the pond have been spelling grommet as a cross between its "proper" spelling and Wallace's companion :-D :poke:
Hence the picture! Titles now sorted.
Peter_W wrote:To my relief the sizes match as I forgot that you are all in the process of "metrication" and that the ruler in Geoff's liked picture was in metric denominations :bonk:
Well it does say 'MM' and the Elan uses a Japanese engine and metric nuts and bolts... :D
Postby Peter_W » Thu 23.05.2013, 18:20
My review edits and comments shown in blue:
GeoffSmith wrote:
Peter_W wrote:Having spent some very enjoyable time tossing back a few beers while looking for this thread using LECs search function, I found it again after realizing that you guys across the pond have been spelling grommet as a cross between its "proper" spelling and Wallace's companion :-D :poke:
Hence the picture! I saw that and thought it was clever
Well it does say 'MM' :D That was the clue that tipped me off :roll:
Peter_W
