lack of power...help
Moderators: theelanman, dapinky, Dave Eds, Sy V, GeoffSmith, DaveT, Elanlover, muley, Enright, algirdas, nitroman, clemo, Specky, Nige
Postby sprogg7 » Sun 24.11.2013, 15:46
hi guys
having a problem with my elan. it will start great, run well on tick over and low revs.
if i try to accelerate the engine just seems to die for a second or two then pick up again for a while and then the same thing happens again.
today i stopped on a small hill to turn around because of the above problem (facing up the hill) and within a few seconds it stopped and wouldn't restart.
once on flat ground it started fine. so far i have changed the plugs and leads and replaced both coil packs. could it be a fuel pump problem?
checked for fault codes, none showing. any ideas
srogg7
1990 lotus elan m100
1998 mgf vvc
sprogg7
Re: lack of power...help
Postby epipete » Sun 24.11.2013, 18:18
Fuel pressure??? check the pump!
Postby briks » Sun 24.11.2013, 21:15
I believe there may be a switch in the seatbelt assembly to provide ignition cut-out if the car goes turtle... could yours be stuck/defective? Best, Bob
briks
Postby Brit-Car-Nut » Sun 24.11.2013, 21:52
The only switch I see in the circuit diagram is the one to turn on the tell-tale light on the dash. On Fed Cars, it might also connect to the warning buzzer control under the knee bolster, but nothing that points to a car shut off device. There is an inertia switch in the battery area to handle serious shunts or roll-over events. The ECM shuts the engine down if it doesn't see the fuel pump getting power.
Postby sprogg7 » Mon 25.11.2013, 09:59
thanks guys.
i have checked the switch (in the battery compartment) and it seems to be working out.
any others ideas will be most welcome
cheers
sprogg7
1998 mgf vvc
sprogg7
Postby sprogg7 » Sat 14.12.2013, 14:48
Hi Everyone
thanks for all the advise. i have changed the fuel filter and also found i had a faulty fuel pump relay. semms to have cured the problem
cheers
sprogg
1998 mgf vvc
sprogg7
