What does this bolt look like?
Postby Simon_P » Sun 01.01.2017, 17:09
I can't find the bolts that hold on the infill plate.
Bolt part no A100E6191S
Does anyone have a picture or can you give dimensions, captive washer(s) etc
I can' find either of them so they are probably somewhere safe.
Thanks,
Simon
Re: What does this bolt look like?
Postby Elanlover » Sun 01.01.2017, 17:41
A "slightly" better description of the part and/or area might help as there are LOTS of parts in the manual that are refereed to as "infill" in some fashion.
Postby Simon_P » Sun 01.01.2017, 17:44
I usually just put the part number in google, but if it helps...
http://www.deroure.com/diagrams.asp?MAK ... 0&ST=&SC=0
17
I'm looking for the bolt "Bolt part no A100E6191S" rather than the infill
Postby Elanlover » Sun 01.01.2017, 17:49
I see it now. Was looking in the interior section (where most of the "infill" parts are) not the engine section. Parts manual doesn't provide enough detail nor a good drawing to determine what the bolt looks like. Can't help unfortunately. :oops:
Postby GeoffSmith » Sun 01.01.2017, 19:36
Unfortunately it's not listed in any of the other sections of the manual either.
Postby lotusflasherman » Sun 01.01.2017, 22:30
Simon,
They (2 of) are in the Parts Manual Page 40.05A Item 17 and shown in Service Manual EC on Page 9 Torque Summary as torqued to "2.4(17.4 lbf.ft)".
They are deep 12mm headed bolts and the lower one is used for the engine earth strap ...
I'm sure you can measure the depth and thread needed to find substitutes ... and as soon as you do Sod's Law says you'll find the ones you've mislaid... :lol:
