by don6962 » Thu 18.06.2020, 10:18
Hi do Powerflex or any other manufacturer supply a poly bush kit to replace all the bushes on the Elan?
91 ELAN BRG
don6962
by Fredjohn » Thu 18.06.2020, 10:33
don6962 wrote:Hi do Powerflex or any other manufacturer supply a poly bush kit to replace all the bushes on the Elan?
Don't know the maker, but SJs sell poly bushes for the Elan.
See here
Elan S4 DHC 1969
Evora 2010
MB E250 CDi coupe 2013
Boardman Endurance SLR 9.4 disc 2018
Rapido 746 2010
by dapinky » Thu 18.06.2020, 10:39
South West Lotus also do poly bushes.....
..... sometimes they are cheaper from SJ's, sometimes from SWL (but never much in it) - overall, a complete set will be the same price from either supplier.
(they are all made by the same supplier to both of these retailers)
- LEC Administrator
by don6962 » Thu 18.06.2020, 13:02
Cheers does anyone know the part numbers for a full set?
91 ELAN BRG
don6962
by Fredjohn » Thu 18.06.2020, 13:19
don6962 wrote:Cheers does anyone know the part numbers for a full set?
I suspect there isn't such a number.
You'll have to either compile the various items on SJ's or SW Lotus website to create an order, or speak to either of them on the phone.
Elan S4 DHC 1969
Evora 2010
Rapido 746 2010
by Saltire » Thu 18.06.2020, 19:07
I did mine eighteen months ago. There isn’t a “set” as such; you need to compile a list from DeRoure and/or the parts lists.
For what it’s worth, I would counsel against using poly bushes all round. When I researched the situation, some OEM bushes were no longer available and I had to have polyurethane. I was strongly advised by a number of Lotus cognoscenti not to use poly on the raft, because it works in a different way from what Lotus intended and changes the handling of the car.
In the end, I bought OEM where I could from either SJs or Kelvedon, including all the raft bushes, and polyurethane for the remainder.
1995 Elan S2, BRG
2016 BMW 440i MSport
2022 Mini Countryman Cooper S
- Location: Left foot in Wiltshire, right foot in Gloucestershire, heart in Scotland
by rip » Thu 18.06.2020, 22:13
Saltire wrote: I was strongly advised by a number of Lotus cognoscenti not to use poly on the raft, because it works in a different way from what Lotus intended and changes the handling of the car.
That makes sense. The rafts are supposed to move a little & are a major design feature of the M100, not just another component. Lotus engineers will have used the correct size/material combination to provide the optimum movement.
Poly bushes will be less flexible, so the rafts won't move as much as they are designed to.
by Rusty Wishbone » Fri 19.06.2020, 10:54
Saltire wrote: In the end, I bought OEM where I could from either SJs or Kelvedon, including all the raft bushes, and polyurethane for the remainder.
This is what I would do too. I take the view that, if polybushes are the best type of bushes to use, Lotus would have fitted them in the first place.
Rusty Wishbone
by Simon_P » Fri 19.06.2020, 11:41
Saltire wrote:because it works in a different way from what Lotus intended and changes the handling of the car.
As do the wishbone bushes which are interleaved rubber (Metal/Rubber/Metal/Rubber/Metal) to change their properties, they use the resistance of the rubber whereas poly are designed to rotate.
A few years ago I investigated getting the bushes remade, I found a company that could do the job, but then found enough bushes to get the job done. Then again last year I needed another set and contacted the supplier, It got put on the backburner (car in pieces) until last weekend when I started work on the rear suspension and find myself in need again. So now I need 3 sets.
I have re-made the contact with the manufacturer and it would be useful to know if anyone else needs some so I have numbers when discussing the quote - expressions of interest here please
viewtopic.php?f=85&t=28114
