Upgrade spark plug?
Upgrade spark plug?
Postby johnj » Thu 22.08.2019, 20:00
Is it worth upgrading spark plugs to platinum or iridium?
johnj
Re: Upgrade spark plug?
Postby GeoffSmith » Thu 02.01.2020, 20:08
Not sure, but I've just grabbed a set of Denso IK20TT iridiums from Opie Oils via Amazon for a very reasonable £36.30.
I was sucked in by the engineering and sales pitch!
USB ElanScan interfaces - £60 incl. P&P.
Postby GeoffSmith » Thu 02.01.2020, 20:32
Amazon order cancelled. Let's try the even more reasonable FleaBay specials for £25.50.
Postby Saltire » Thu 02.01.2020, 21:58
GeoffSmith wrote:Amazon order cancelled. Let's try the even more reasonable FleaBay specials for £25.50.
Well spotted, Geoff - I’ve just ordered as well, along with a couple of NGK coil packs. Trying to get some Kingsborne plug leads, but their website’s a nightmare for non US buyers.
2020 Volvo XC40 T4 AWD
Postby GeoffSmith » Thu 02.01.2020, 22:14
They're about 10 miles away from Tiger Doug. Drop him a message if you are having a problem. Tell him I sent you. Better still, maybe best not to tell him I sent you. :lol:
Postby Saltire » Thu 02.01.2020, 23:55
OK, thanks, I’ll see if they reply to my overnight email.
Postby GeoffSmith » Wed 08.01.2020, 14:22
GeoffSmith wrote:I was sucked in by the engineering and sales pitch!
Sex on a stick!
Postby Saltire » Wed 08.01.2020, 16:30
Mine arrived yesterday. Red Kingsborne leads in the way. For future reference for anyone who’s considering the same leads, I Spoke to Kris Richter - very helpful chap.
Postby TrevorB » Wed 08.01.2020, 16:31
On ebay it gives you the option to check if it fits your vehicle. When I went through that process it told me it's not suitable
for the 1992 Elan Turbo ??
Short shift conversion
HiSpec's
Wannabe Princess
Postby Saltire » Wed 08.01.2020, 16:40
Hi Trevor
I’ve never found the eBay “Does it fir your vehicle?” tool to be anything other than patchy. All I can tell you is that the Kingsborne web site lists our car, they knew about it when I spoke to them, they were made to order, and BCN in Charlotte told me in passing that he has a set to fit to his car.
I’ll let you know what happens when they arrive!!
Postby Brit-Car-Nut » Wed 08.01.2020, 17:51
To be accurate, I told Jonathan I have a set of blue 7mm Kingsborne ignition cables. I still use BKR6E plugs (gapped correctly).
Look at the WikiLEC!
Lotus Manuals
Postby Rambo » Wed 08.01.2020, 20:34
Sex on a stick!
Is that the right gap Geoff ? You're not boasting again are you :twisted:
Postby Saltire » Wed 08.01.2020, 20:41
Brit-Car-Nut wrote:To be accurate, I told Jonathan I have a set of blue 7mm Kingsborne ignition cables. I still use BKR6E plugs (gapped correctly).
Quite right, John. Apologies if I implied otherwise :oops:
Postby Simon_P » Thu 09.01.2020, 00:24
johnj wrote:Is it worth upgrading spark plugs to platinum or iridium?
In a word no!
