Causes Of Ignition Not Turning Off
Re: Causes Of Ignition Not Turning Off
Postby CallMeLegend » Sun 28.06.2020, 20:10
Rambo wrote:Your alternator isn't working ccorrectly as I suggested previously :? You should get ~14+ V across the terminals. Immediately and not a gradual increase as you are experiencing.
I suspect your regulator/diode pack.There have been mutiple examples of alternators packing up in recent times
I did measure the voltage at the battery as I didn't have time.e to get to the alternator
CallMeLegend
Postby Rambo » Sun 28.06.2020, 20:12
Simon mentioned something earlier which implied things weren't quite right
Simon_P wrote:I might be wrong but it looks like 13v with a +-0.1v ripple. Interesting? ;-)
Postby Simon_P » Sun 28.06.2020, 22:07
Well spotted Rambo - I took that from Steve's last post with an elanscan.
12.3v is flat and charging slowly.
Postby GeoffSmith » Sun 28.06.2020, 22:15
More evidence that it is the alternator. Pull the plug and see if the light goes out.
Postby CallMeLegend » Sun 28.06.2020, 22:53
GeoffSmith wrote:More evidence that it is the alternator. Pull the plug and see if the light goes out.
Yep. Next move. Need to find a full day to fault find really. Doing 30mins at a time is pretty inefficient.
CallMeLegend
Postby Saltire » Mon 29.06.2020, 07:50
Mark, I’ve just had my alternator and starter refurbished to a really good standard by a family firm in the West Midlands (see below). I can’t remember the contact details off the top of my head, because it was ‘friend of a friend’, but I can probably dig them out for you.
1995 Elan S2 no 512, BRG/magnolia, last of 4 UK S2 to this spec - SORN
2020 Volvo XC40 T4 AWD
Postby Rambo » Mon 29.06.2020, 08:39
Jonathan - if Mark doesn't want the details, the other Mark, and half of LEC might
Postby CallMeLegend » Mon 29.06.2020, 09:08
Saltire wrote:Mark, I’ve just had my alternator and starter refurbished to a really good standard by a family firm in the West Midlands (see below). I can’t remember the contact details off the top of my head, because it was ‘friend of a friend’, but I can probably dig them out for you.
Yes please, that would be very helpful if I bottle doing it myself.
CallMeLegend
Postby Fredjohn » Mon 29.06.2020, 09:18
Just had mine refurbished by a ham fisted diyer. He used a group buy kit from LEC. Was very cheap but removing alternator is a pig of a job. So is putting it back.
But it's now working fine. Quite pleased with my work really :D
Elan S4 DHC 1969
Evora 2010
MB CLK 320CDi 2007
Swift Sundance Lifestyle 500
Postby dapinky » Mon 29.06.2020, 10:19
John,
I think I must use the same mechanic (I recognise the description).....
..... but the kit you (we) got wouldn't necessarily address the specific issue Mark has got, as it appears to be the electronic gubbins inside which is buggered (to be technical).
