Fuel smell on startup
Moderators: theelanman, dapinky, muley, Enright, algirdas, nitroman, clemo, Specky, Dave Eds, Nige, GeoffSmith, DaveT, Sy V, Elanlover
Postby Danevansgolf » Mon 27.06.2016, 09:37
Hi there, I'm sure there's a thread for this, but cannot find it.. On start up of my car i can smell quite a bit of fuel. What is the cause? This started a couple of months ago now. Any help?. could it be the injectors?
Danevansgolf
Re: Fuel smell on startup
Postby HJ2 » Mon 27.06.2016, 11:45
Don't rule out a cracked filler neck on the fuel tank.
You can do a search on this in the Search box on this page in the almost upper right corner!
Good luck.
Postby Rambo » Mon 27.06.2016, 20:14
There appear to be quite a few LEC'rs experiencing this phenomenon recently. As HJ says, use the search facility to find out more
Wherever the petrol smell is coming from, it needs urgent investigation :shock:
Postby Danevansgolf » Wed 29.06.2016, 07:58
The smell is only when the car is a started initially. Then disappears. I know all about the fuel tanks crack, I haven't looked, but I only fill the tanks 1/2 full, which seems to help. I thought It might be a blast of excessive fuel from the exhaust on startup. This is why I thought it might be the injectors, as the car takes a long time to start on the key 3-6 seconds. I'm going to strip and clean the injectors to see if they are blocked or leaking. Part of the try and see and eliminate. Cheers
Danevansgolf
Postby tb10 » Wed 29.06.2016, 09:12
Rambo wrote:There appear to be quite a few LEC'rs experiencing this phenomenon recently.
I've had this problem in the last week and then saw this thread WTF?? :shock: :shock:
I'm assuming it's nothing to do with the outcome of the Referendum as everyone is blaming that for everything else at the moment.........! :lol:
regards
tb10
