White smoke and sounding a bit clattery
Re: White smoke and sounding a bit clattery
Postby Rice crispy » Wed 01.02.2017, 00:09
Steve I haven't had it done as the sniff test didn't show a failure and a pressure test lost a tiny amount after about 30 minutes. So far I've replaced the header tank and cap as a precaution and the water level has stayed level since I posted so hopefully it was one of them but I couldn't see any where they had failed. I will monitor it through the next few months as it will get more use again as the salt disappears and it warms up.
Rice crispy
Postby Steve A » Fri 03.02.2017, 20:46
:D Well I've done the (careful)sniff test and all seems to be well, the drop in coolant turned out to be a slight leak at the offside front :roll:
It's weird because it wasn't even clattery when it started :?
Postby John_W » Fri 03.02.2017, 20:52
Steve,
Glad to hear it's ok and that paranoia is alive and well.
:bonk:
Postby Steve A » Fri 03.02.2017, 21:04
John_W wrote:Steve,
:bonk:
:lol: Your not wrong :lol:
