code 54
code 54
Postby lotustonybassplayer » Sat 29.04.2017, 17:14
I have code 54 0n paperclip test ,the co pot ?, I recently fitted new gear cables and short shift :-D went out for a test run suddenly had a loss of power and engine light came on then it cleared and got me home ok that was last week . just tried it again still similar just about managed to pull out of garage :shock: i can here a intermittent rattle from under the rocker cover by the CAS which seems to coincide with a fluctuation with the rev counter whilst ticking over, taken off CAS cover and run engine nothing obvious to be seen . CAS on the way out :?:
lotustonybassplayer
Re: code 54
Postby TrevorB » Sat 29.04.2017, 17:31
:( :( Sorry to hear of your problems Tony hope you get it sorted. Enough expertise on here to help. Not me unfortunately :D
Trevor
Short shift conversion
HiSpec's
Wannabe Princess
Re: code 54
Postby lotustonybassplayer » Sun 30.04.2017, 16:35
Cleared code with a battery disconnect :-D all running smoothly now :D think problem stemmed from a loose spark plug lead !
lotustonybassplayer
Users browsing this forum: Google [Bot] and 1 guest
