Seat spacers
Seat spacers
Postby simonbuk » Tue 05.09.2017, 17:08
Can anyone remember which spacer under the seat is different ?
I remember their being a different height to only one of them I think but can't remember which one.
Also I noticed that the spacers under an SE are different height to an S2 - why is this ? Different seat design ?
Black S2 No.357
Aqua Blue S2 No.385
Simonthesailor
simonbuk
Re: Seat spacers
Postby simonbuk » Tue 05.09.2017, 17:30
Ok, so it's the rear outboard spacer that is different by approx 4mm whether it's an SE or S2.
When I put some washers together to make about 4mm the seat looks lop sided still, so still needs more of a lift.
Basically what I've noticed is that when I fitted Kermit's SE seats to my S2 without any spacers underneath (I need the space) I walked up to the car and noticed the drivers seat was falling brown to the left as you look at.
Black S2 No.357
Aqua Blue S2 No.385
Simonthesailor
simonbuk
Re: Seat spacers
Postby dapinky » Tue 05.09.2017, 17:35
I didn't know that the spacers were different between SE/S2 - every day is a school day!
... but I did (do?) know that the seat base design is different, so it makes sence to allow the S2 to be at a different height, I suppose....
Basically, the SE seat has a rubber diaphragm to support the driver, whilst the S2 has a metal sheet as a base below the foam - therefore, there should be far less 'sag' on an S2 seatbase, and thus less space is needed below???
Re: Seat spacers
Postby simonbuk » Tue 05.09.2017, 19:28
That seems to make sense yes !!
I need to get a spirit level on my seat as it's doing some strange things..........
Black S2 No.357
Aqua Blue S2 No.385
Simonthesailor
simonbuk
Re: Seat spacers
Postby theelanman » Wed 06.09.2017, 11:48
the se ones are bigger than the s2....
I found this out when I did my car :-D
Re: Seat spacers
Postby simonbuk » Wed 06.09.2017, 12:14
As in deeper in the seat ?
Black S2 No.357
Aqua Blue S2 No.385
Simonthesailor
simonbuk
Re: Seat spacers
Postby theelanman » Wed 06.09.2017, 12:46
yes the se versions are taller.......
Re: Seat spacers
Postby theelanman » Wed 06.09.2017, 12:53
see the remarks column
Re: Seat spacers
Postby simonbuk » Thu 07.09.2017, 06:57
I don't really understand this ? If the SE seats are taller and they have bigger spacers then surely you would sit a lot higher up in the car ?
You would have thought that the taller seat would have the smaller spacers, and the shallower seat the larger spacers ?!
:confused:
Black S2 No.357
Aqua Blue S2 No.385
Simonthesailor
simonbuk
Re: Seat spacers
Postby theelanman » Thu 07.09.2017, 08:57
its all to do with your behind falling through the bottom of the seat...... :-D
Re: Seat spacers
Postby simonbuk » Thu 07.09.2017, 09:07
Oh well, my bottom is now cared for in alot softer way and I still seem to be sitting equally or maybe a slight bit lower so I'll shut up !! :D
Black S2 No.357
Aqua Blue S2 No.385
Simonthesailor
simonbuk
Return to Interior
