Removing the Gear Knob
Postby MGMoore » Mon 28.12.2020, 18:13
I want to remove the gear knob to repair the gaiter, I’ve found and removed the tiny grub screw and believe the Gear Knob should unscrew, but it will not move! It is a very early model from 1989, any ideas please? Thanks Mark
MGMoore
Re: Removing the Gear Knob
Postby Blaster » Mon 28.12.2020, 19:26
Mine was just screwed on.
Tony
1990 Lotus Elan SE 2009 Triumph Daytona 675SE
2012 KTM Freeride 350 2008 VW T5 4-Motion camper.
2019 Ace aviation Spirt 16 2018 AC Nitro 200 Ozone Speedster
Blaster
Postby TorqueHorse » Mon 28.12.2020, 21:08
Mine was tight too, but finally came off. Try to use the metal collar on the bottom of the knob and not the actual leather knob to twist. Try some vice grips, provided you protect the metal collar surface, to gain leverage.
'90 FED M100 -mid resto
Postby MGMoore » Tue 29.12.2020, 14:27
Thanks both, masking tape on the metal to protect it and grips removed it, now to stitch in some leather on the inside of the gaiter to repair where it has split open at the top.
MGMoore
Return to Interior
