Custom Pedal Covers
Postby Elanlover » Mon 01.10.2007, 19:23
Quick update:
Spoke to the manufacturer today. They received the templates but won't have a chance to review them until week's end at which time he'll let me know if my tracing skills were good enough for him :roll: I expect to hear back early next week as to whether he can start making them or not.
For those who wanted a smaller clutch and brake pedal I'm hoping to convince him to offer an M100 Elan "A" and "B" pedal set as I think I've seen him do for a handful of other cars they make product for. The "A" set would be an exact match for the pedals with the rubber cover on. The "B" set would have a smaller cluthc pedal cover equivalent in size to the pedal without the rubber cover on. The reason I think I may be able to get him to do this is that when I originally contacted him he said they had M100 covers already in stock. The diagram e-mailed me had them match only the pedals with the rubber covers off, not with them on. Apparently, these were for another model car that he was told would also fit the Elan. So, he's already got smaller pedal covers that match the Elan pedals with the covers off - no additional manufacturing to do. Should be easy enough to get him to offer a few size combinations.
Once I've seen the pedals for myself I will work on a Fed, driver's side footrest template too. I've also noticed they make some awfully nice, matching sill plates too :wink:
Postby Elanlover » Thu 11.10.2007, 20:11
Another update:
Spoke to the manufacturer (really nice people) and he's loaded the templates into CAD. He'll be e-mailing me paper templates to do one last fitting before he begins machining them. Probably won't start until next week but I expect to receive them within 2 weeks from then. I'll report back as to fit with plenty of pics when they're installed. If its a good fit, he'll start listing them on the website for sale.
As for sizing, I've sent him templates of the EXACT size of the clutch and brake pedals with the rubber covers ON. Some of you have expressed interest in pedal covers that are smaller than the rubber ones. He has sent me templates for covers that are a practically an exact match for the pedals WITHOUT the rubber covers and I'm going to test fit a template with one of each size. Its no problem for them to offer an "A" and "B" option that would allow you to specify larger or smaller pedal covers. Obviously, the gas pedal has no cover so no need to worry about that. I'll let you know how it all turns out.
Also, with all the discussion about door sills from previous posts I asked him about his sills. They look quite nice and can match the pedal covers. Here's a few pics.
Postby Elanlover » Wed 17.10.2007, 02:37
Update #3:
Cover dimensions now finalized. The gas pedal cover is ever so slightly larger than the bare metal plate. The smaller clutch/brake cover is ever so slightly larger than the bare metal plate - perfect for those of you who want a smaller pedal there. The larger clutch/brake cover is a perfect match for the pedal with the OEM rubber cover on.
Will hopefully have them soon and will post results and pics when installed.
Postby Elanlover » Fri 26.10.2007, 01:18
The pedal covers have arrived and i must say they look pretty darn nice. These guys do a good job. I plan on fitting them this weekend after which I will post pics and provide final feedback on size and feel once I break them in :-D
Postby Elanlover » Sun 28.10.2007, 23:47
Pedal covers are installed and they look quite nice and feel great. Tokk all of about 40 minutes to do - mostly because I was in the garage doing it and couldn't open the door fully to get closer to the pedals.
Overall, they are quite easy to install. The real key is to pick your mounting holes carefully. Make sure you are going to drill where the back will be as flat as possible. There's a lot of weld seams back there that make the surface uneven and therefore hard to get a nut to sit flush and tight on the back.
Ok here's what they look like:
Postby Elanlover » Tue 30.10.2007, 14:02
The vendor will have these up for sale shortly. After a few days of driving with them I have to say they really feel nice. These will be MUCH better than a generic set of pedal covers which will probably be too big (at least from what I've seen out there). I've asked him to offer the larger brake/clutch and the smaller brake/clutch covers as "individuals" so people can buy 2 large, 2 small or mix and match them. The gas pedal is ordered seperately.
Keep in mind that these are designed specifically for our car. The large brake/clutch pedal is an exact match for the size of the current rubber cover. The smaller brake clutch is just slightly larger than the base metal plate that the rubber covers normally fit over. Should be perfect for those with big feet that are looking for a smaller pedal :wink: The gas pedal is just slightly wider than the base metal plate to ensure a good fit. They are also curved to match the curvature of the current pedals and will fit nice and tight up against the base metal plates.
I don't know about the rest of you but what turns my crank is someone who goes out of their way to provide excellent customer service. This guy was fantastic. He spent a lot of time making revision after revision of templates in order to make them absolutely perfect and wouldn't settle for them being otherwise (even when I told him they were "close enough"). He takes a lot of pride in his work and reputation. If you're looking for pedal covers, these, while being more expensive than most others out there, are definitely the ones.
And no, I don't get a kickback or make any commission on units sold. I didn't even get a "test subject" price reduction on the first order :lol:
Postby paulwatkins » Tue 30.10.2007, 14:33
Elanlover wrote:The vendor will have these up for sale shortly.
Will the company let you know when they are available to order on-line?
I look forward to ordering a set.
paulwatkins
Postby Elanlover » Tue 30.10.2007, 14:48
Yes, I've asked him to forward the link to me once he's added it to his site so I can post it here. In the meantime, you can order by e-mailing him at sales@ultimatepedals.com. His name is Rob Baylor - very nice fellow.
Postby paulwatkins » Thu 01.11.2007, 08:19
Blair,
I emailed Rob yesterday, and my pedals are now on order! :-D
If anyone else would like to order a set of pedals, here is a copy of the email I received from Rob with the instructions
No problem to make a set of pedals for your 1991 Lotus Elan SE (we already have the templates) and ship them to the UK.
Pricing would be identical to our Porsche 911 pedal pricing.
Please click on the following link to see our 911 products (select a product then scroll down for finish options with pricing):
LINK TO ULTIMATE PEDALS
Custom engraving cost is $10 per pedal.
(see image file below)
If you would like to proceed with the order simply order the 911 pedals that you would like, but specify your 1991 Elan, what size brake and clutch pedals you want (large or small, Blair ordered one of each) and any engraving during the checkout process when you are asked to indicate year, make, and model.
We will then match the pedals for your 1991 Elan instead of the 911 when we manufacture your order.
Please let us know if you require any additional information.
No questions asked moneyback guarantee if you are not satisfied with the fit or finish.
Don't settle for "One Size Fits All" pedals.
Have a great day!
Rob Baylor
www.ultimatepedals.com
(561) 798-6588 Phone
(561) 798-6994 Fax
paulwatkins
Postby Elanlover » Thu 01.11.2007, 14:47
I'm sure you'll like them as much as I do. If you need any help at all installing just PM me. The instructions he sends along with the pedals are pretty good though.
Postby Ekapol » Fri 09.11.2007, 02:32
I see you have Lotus Type1 on your wrist :smt023
http://www.lotuselancentral.com/forum/d ... hp?id=6155
Ekapol
Postby Elanlover » Fri 09.11.2007, 03:21
Ha! Observant you are. Tell Lotus time I can.
Postby paulwatkins » Wed 14.11.2007, 18:13
Blair,
my new pedals have arrived! But I probably wont get around to fitting them for a while yet.
I had a chuckle when I saw the size of the box that they came in! :lol:
They are machined really well. The logo looks good upclose (the pic doesnt show it very well), and will probably improve when the impressions fill with grime.
BTW if anyone wants to know, they were £80 delivered to UK including the logo.
paulwatkins
Postby Elanlover » Wed 14.11.2007, 23:38
Looks nice! I especilly like the gas pedal witout any antislip grooving on it. Let us know how the install goes.
Postby paulwatkins » Sat 23.02.2008, 19:42
Blair,
I finally got around to fitting these today! :oops:
They were pretty easy to fit.....once I'd managed to get myself into the footwell! :lol:
I went for the smaller type of pedal; which is just slightly larger than the bare metal plates when you remove the rubbers.
paulwatkins
Postby Elanlover » Thu 28.02.2008, 01:17
They look great Paul. These guys do nice work don't they :wink: I am going to send him my plastic door sill shortly to see if he can work out a nice aluminum sill for us. A foot fest for Fed cars is also on the list.
Postby nitroman » Tue 22.04.2008, 22:40
Do you guys notice that your foot (escecially when wet) slips around or off the pedals?
nitroman
Postby Elanlover » Wed 23.04.2008, 02:16
Matt, never. There's lots of options on these pedals including a no slip finish as well as rubber domes to address that. They're pretty good when wet. There's bound to be "some" sliding but its been pretty minimal or virtually non-existent for me.
Postby Doug » Wed 23.04.2008, 03:54
but Matt they are so clean and shiny looking -- how can you not . . . .
