Aluminum Door Pulls and Handles - Who's Interested
Postby Doug » Wed 23.04.2008, 05:49
you could always paint CF to look how you like -- at least it is light weight
Al is light too -- I like Brian's Al door pull design, but I'd change the angles of the cutout to better parallel the surrounding area. But I ain't got no Elan to put them in :? I like the feel of solid metal on the door pulls from experience in other cars, you could even put finger ridges on the rear side for some custom feel when you pull it . . .
Postby Elanlover » Wed 23.04.2008, 13:26
A thought just occurred to me regarding the conecpet of a one-piece pull/escutcheon part. But, I should preface my comment by saying that I'm not in favor of the idea to begin with and yet don't want to seem negative about it for the sake of others who like the concept.
The pull mounts to the door by 2 screws from the back - the inside of the door panel. The escutcheon by 1 screw into the front of the door panel. Would this arrangement make it difficult to install/remove the part? I find the escutcheon hard enough to get off on its own sometimes. Having to wiggle the door handle, etc. to remove it. Can you imagine what it'd be like trying to remove the it if it was attached to the entire door panel? :shock: I'd be afraid of damage to the CF part (scratching the finish, etc.) when removing/installing it. When the "pull" portion of the part is screwed into the back of the door, would the escutcheon screw hole then line up perfectly every time? You'd have to remove the door panel if you only wanted to get at the handle or behind the escutcheon.
Now, perhaps Brian can work his magic to make all these possible issues moot but, I can't help but wonder if there was a reason why Lotus did it this way...........
Postby theelanman » Wed 23.04.2008, 15:40
personally I prefer the CF escutchion and the alu door pull.....
b;ack carbon bits and shiney metal bits :-D :-D :-D :-D
Postby nitroman » Wed 23.04.2008, 16:30
As to aboved 2 posts, I'll add... consider that some people want only the 'pull' & not the escutchion.
Doug wrote:I like Brian's Al door pull design, but I'd change the angles of the cutout to better parallel the surrounding area.
Ditto. I liked what I thought were oval cutouts on the original picture.
nitroman
Postby Gee0 » Fri 25.04.2008, 09:33
OK go on then
I like the first detailing(cut outs) on both the handle and pull, mostly the pull the handle needs refining IMHO
1. Elanlover
2. theelanman
3. Matt RI
4. Drasicjazz
5. LGM (depends on design and cost)
6. Paul.P
7. Sy
8. Router
9. Redvette6327
10. rip
11. Ekapol (depends on design and cost)
12. Ailwyn
13. Ailwyn (2nd set dependant on cost)
14. John Price (dependent on cost)
15. Nitro (design posted on prior page by F1Lotus)
16. Gee0 (depending on costs and design)
Gee0
Postby F1 LOTUS » Fri 25.04.2008, 20:24
The details are pretty crude at this stage as I really need to get hold of some parts to find out how complex the machining task might be? Once I know this I can get cost estimates that will indicate if this project is feasible or not :? Until then it's not worth spending too much time dicking with styling, although the feedback is welcome for when (hopefully) we pull the trigger on this :)
F1 LOTUS
Postby Elanlover » Fri 25.04.2008, 20:32
Brian, can't remember if I PM'd you or not but you should have a pull and handle delivered sometime next week.
Postby F1 LOTUS » Fri 25.04.2008, 22:17
You mentioned that you may have a source - glad that it worked out and parts are on their way - well played young man! :D
F1 LOTUS
Postby paulwatkins » Sat 26.04.2008, 07:24
Brian,
could these be done with a more subtle finish applied to them? Something like a brushed effect finish?
I'm not too keen on super shiny bling in the cabin area. Its a bit too Halfords Ripspeed for my liking. :lol:
Each to their own of course :oops:
paulwatkins
Postby F1 LOTUS » Sat 26.04.2008, 08:45
paulwatkins wrote:Brian,
Easy! Just take a Scotchbrite pad to aluminum for a brushed-satin finish :D
F1 LOTUS
Postby paulwatkins » Sat 26.04.2008, 10:05
In that case, I'll add myself to the list.
1. Elanlover
2. theelanman
3. Matt RI
4. Drasicjazz
6. Paul.P
7. Sy
8. Router
9. Redvette6327
10. rip
12. Ailwyn
17. paulwatkins
paulwatkins
HANDLES
Postby JETRO » Sun 27.04.2008, 01:30
CAN I STILL GET A SET? IF SO INCLUDE ME PLZ!
Warning Warning Do not let your friends drive your Elan it will end in tears!
JETRO
Re: HANDLES
Postby F1 LOTUS » Sun 27.04.2008, 01:52
JETRO wrote:CAN I STILL GET A SET? IF SO INCLUDE ME PLZ!
Sure!
We're still at the 'who's interested?' stage, detail design and costing I would hope to begin next week some time :)
F1 LOTUS
Postby F1 LOTUS » Tue 06.05.2008, 20:25
I've refined the models and had them out for quote, both as a simple 'plain' design and, as a bells and whistles light-weighted version :roll:
There's approximately $15 more machining per handle for the fancy version.
Costs - right now the 'fancy' version would be $130 each, the 'plain' $115 each. There are a few tweaks I can do that could get the costs down a bit, also sticking my neck out and getting 20 car-sets made will improve costs.
Given that this is the cost 'ballpark', now's the time to indicate if you're still interested?
The thumbnails below link to 3D PDF models that anyone with Acrobat 7.0 (or later) can open then spin, pan or zoom until your heart
s content or, something good comes on the TV :?
Have fun, let us know!
Image Image
F1 LOTUS
Postby Elanlover » Tue 06.05.2008, 20:31
Brian, I'm "IN" and am also interested in matching door "handles" to go with the "pulls" displayed above.
1. Elanlover
2.
Postby theelanman » Tue 06.05.2008, 20:59
1. Elanlover
2. theelanman
Postby Elanlover » Tue 06.05.2008, 21:16
Just so we're clear I'll add in the "handles" part which I assume will be somewhat less than the pulls given their size and shape.
1. Elanlover (pulls + handles)
2. theelanman (pulls + handles)
Postby Doug » Wed 07.05.2008, 02:17
took me a while to get the angle right to see your interior reflected in the handles -- I'm always interested to see what's in the reflection--was hoping for something more risqué :oops:
beautiful work BTW :smt024
Postby F1 LOTUS » Wed 07.05.2008, 03:22
So you didn't see the playmates draped across the seats then... :D
F1 LOTUS
Postby ailwyn » Wed 07.05.2008, 09:02
3. Ailwyn (fancy pulls + handles)
4. Ailwyn (fancy pulls + handles)
