Monty wrote:If your comparing to Lockwood why not compare prices?
BTW replacement LEDs are a waste of time, done that, been there and had to go back to stock bulbs
GeoffSmith wrote:McMurph, can you remember which LEDs you tried? I was going to give UltraLEDs a try as I've got several gone.
Blair, which ones did you go for? Much as I admire Joseph Swan, his days are numbered.
Nige wrote:Monty, didn't you try blue LEDs? If so I think the blue LED shining through the orange of the Lockwoods would be what made them very dim. I still haven't got my instrument lighting working since fitting the MM dials but that's my electrical ineptitude and no chance to investigate yet, not the dials. When I do get it working mine will be white on black when not lit and green on black when lit. The MM dials are expensive compared to the Lockwoods and it's a matter of choice.
Monty wrote:If the ones that you're getting from Crazyleds fit that should do the trick since it's a cluster of 4 LEDs with gives a wider beam.
