s2k seats fitted.
s2k seats fitted.
Postby Jamie N » Sun 21.03.2010, 21:45
Always liked these style of seats and managed to find a set at a good price on friday,managed to install them today,fairly straightforward but time consuming,had to make four pieces for each seat from flatbar as pictured which then lined up with the original holes.
It was not possible to swap the runners as the s2k ones are integral to the seat construction,the way i have bolted them is rock solid,doesnt look out of place,seats slide perfectly,no issues with clearance,in fact the base is not quite as wide as the original seats so they dont even touch the centre console,roof folds no problem and the shoulder bolster has about 25mm clearance with the door shut.
I think they update the interior just nicely,but would be interested to hear the general consensus :D
Monaco S2 #406
Jamie N
Seal God
Re: s2k seats fitted.
Postby kenich » Sun 21.03.2010, 22:00
They are suited well to the Elan I think. I have watched a few on eBay recently, they seem easily available.
Good work :-D
kenich
Postby abmunro » Sun 21.03.2010, 22:10
Did you wiegh them before installing them?
Tony
abmunro
Postby abmunro » Sun 21.03.2010, 22:13
Found out myself 35lbs
see link
Honda S200 seats
abmunro
Postby muley » Sun 21.03.2010, 22:57
I think they look good - I might go down this route myself.
Good pics, thanks
Rgds
Postby Jamie N » Mon 22.03.2010, 18:44
Here is a view from the back of the car with the roof down.
If anyone wants to fit these to their Elan i can make up the full set of brackets supplied with the right bolts,a couple have to be shimmed down on the head in order for the handle on the runners to pass when moving the seat back and forward.
All four brackets are a different size to fit each respective hole on the floorpan :P .
Monaco S2 #406
Jamie N
Seal God
Postby lotos » Mon 22.03.2010, 21:03
Wow, I really like the look. I don't mind the look of the M100 seats per se but I don't find them especially comfortable. Here in Colorado, I've always pondered getting heated and cooled seats in a convertible.
What's the weight of the stock M100 seats?
lotos
Postby abmunro » Mon 22.03.2010, 22:39
17.5 kg each
Including subframe
abmunro
Postby JIMBO » Mon 22.03.2010, 23:26
Hi dromong,
I was going down this route a month ago but after discussing it
with another forum member I decided it was likely to be too
much fiddling around with an uncertain outcome.
You have now convinced me that this is definately the way to go.
There is a pair of red seats just a couple of hundred yards from
where I work which they will sell for £300.00.
Not sure about red seats in a red car.
Please can you make up a set of fitting brackets for me. I will pm you.
Best regards and well done,
PS
I will have a pair of seats for sale which are in need of refurbishment
if any one is in need ?
JIMBO
Postby esprit888 » Tue 23.03.2010, 01:35
I also have a set of the same seats, new condition, in black sitting in the garage. Paid $250 canadian :D
Will also take a set of the adaptors-see PM
JIMBO wrote:Hi dromong,
PS
esprit888
Postby lotos » Wed 24.03.2010, 21:39
abmunro wrote:17.5 kg each
Including subframe
So given the S2000 weight of ~ 16 kg, you're down 3 kg / 6.5 lbs. Better than nothing!
lotos
Postby Don.Hasi » Wed 31.03.2010, 22:07
the most important question is: when will you kick out the turbo lump of the engine bay and install the honda-engine standing near the wall of your garage? :-D :roll: :wink:
Don.Hasi
Postby tigerdog » Thu 01.04.2010, 18:59
DROMONG wrote:I think they update the interior just nicely,but would be interested to hear the general consensus :D
A right and proper job, IMHO. They look like they belong in the car - so much so, I might consider this route when my seatbottoms eventually give way under my sadly prodigious bulk.
Postby Upset99 » Fri 30.04.2010, 05:08
DROMONG wrote:Here is a view from the back of the car with the roof down.
Yes, I would be VERY interested if you could do this. Pleas IM or contact me with prices and estimated times.
Kevin
Upset99
Postby Upset99 » Fri 30.04.2010, 05:41
What about the Seat Belt Females on the seat? Does the male fit?
Upset99
Postby Rice crispy » Thu 20.05.2010, 18:10
Upset 99 yes they do :D
picked up a pair today :banana: in good condition,
DROMONG sent a PM if you could make me some brackets and fixings that would be great
Rice crispy
Postby Rice crispy » Fri 28.05.2010, 17:24
Well test fitted mine yesterday :banana: made up mounting brackets from 6mm thick rolled cold steel used stainless A2 nuts and bolts (not sure if they are suitable but hope someone on here will let me know if not) would like to lower them slightly and have proper made up mounts made rather than my attempt.
Will post some pics when I charge the camera :)
Rice crispy
Postby enndee » Sun 13.06.2010, 08:18
I have just bought a pair from a 2005 car that had only done 8500 miles AND they are grey with red centre panels and headrests, so will look perfect in my red 1992 SE.
Will post some pictures when they are fitted.
enndee
Postby Doug » Sun 13.06.2010, 17:33
DROMONG, that is a seriously cool garage picture! 2 Elans and a nice mancave = bliss!
Postby Jamie N » Tue 15.06.2010, 13:17
Doug wrote:DROMONG, that is a seriously cool garage picture! 2 Elans and a nice mancave = bliss!
Thats very kind Doug,thank you.
Just an update on the seats,ive used the Elan a fair bit of late and i must say the seats are far more comfy on a longer run than the originals,
so a worthwhile upgrade and not just for aesthetics :wink: .
Jamie
Monaco S2 #406
Jamie N
Seal God
