fitting an omp steering wheel
Postby addict » Sun 28.11.2010, 22:16
has anyone fitted an omp steering wheel any pictures ? i quite like the style thinkin of fitting one myself
addict
Re: fitting an omp steering wheel
Postby kenich » Sun 28.11.2010, 22:55
Iv had a few on previous cars. They do some really good wheels. I have gone for a Momo course on my Elan though.
kenich
Postby kenich » Sun 28.11.2010, 23:03
My old OMP wheels - Suede deep dish 320mm
Small leather 280mm
kenich
Postby addict » Sun 28.11.2010, 23:25
looks good thanks for that
addict
Postby Rice crispy » Mon 29.11.2010, 14:41
Kenich waht boss did you use for your Momo wheel ?
Rice crispy
Postby kenich » Mon 29.11.2010, 19:04
Quick release boss to pop the wheel off the stock hub.
kenich
Postby DeeAitch » Mon 29.11.2010, 20:47
I have the same wheel on my car - bolts straight onto the stock SE boss. You will then need a rubber shroud, I just bought the cheapest Momo kit I could find on fleabay and used the shroud from that.
Bell & Colvill sell the horn push.
DeeAitch
Postby addict » Sat 04.12.2010, 23:55
are the momo and omp the same bolt patern ?
addict
Postby kenich » Sun 05.12.2010, 11:00
Yeah pretty sure it will be the same. As a rule Momo, Omp, Sparco, Raid, Richbrook, and Mountney all share the same bolt pattern.
kenich
Postby andrewp » Tue 20.12.2011, 05:15
If you can find a Momo hub for the Isuzu Impulse you will discover that the shaft taper & splines all match to the Lotus (either Elan or Esprit). This tidbit has been used to solve a bunch of problems for me.
AP
andrewp
Postby Rice crispy » Thu 22.12.2011, 22:34
I have a momo quick release that bolts to the original hub that you can mount a omp or momo wheel on. You would need to make a cowl for the original hub yourself though as that comes off as part of the wheel. Can have it for £25 posted :D
Rice crispy
