Need new lock cylinder
Postby Golly » Tue 03.01.2012, 22:33
Not sure thats what its called, I translated directly. Basically the lock on the driver side is broken, the key turns but doesnt catch. Any idea where I could get my hands on one? I have the KIA elan but I'm assuming the doors are mostly the same.
Golly
Re: Need new lock cylinder
Postby Specky » Wed 04.01.2012, 00:09
Have you confirmed it's the lock at fault?
Does the internal door lock plunger work or any of the central locking, try the other side of the car.
My first guess would be that one of the ball and socket joints on the control rods have parted company.
The door lock cylinders are readily available from the normal suspects.
There is also a thread on alternatives.
Hope that helps
Postby Golly » Wed 04.01.2012, 11:12
Well thats what the car mechanic said. Im new here, im not sure who the normal suspects are :p
Golly
Postby epipete » Wed 04.01.2012, 18:19
Somebody here once suggested Astra mk2 - maybe worth checking!
Postby Specky » Wed 04.01.2012, 19:39
Golly wrote:Well thats what the car mechanic said. Im new here, im not sure who the normal suspects are :p
http://wikilec.9600.org/index.php/Parts
The section should help,
Don't forget the USA conection, now where's that thread...
viewtopic.php?f=8&t=17261&p=247601
If you're in dire straits, could you photograph the item you require and I'll see what I have laying about.
Postby Rice crispy » Wed 04.01.2012, 21:07
Lock kits were on ebay and after sales for about £20 a while ago. I would check as Specky said first as my passenger lock didn't work from outside only inside or on central locking and was link from door to lock had popped off. Was a real pig to get back on but ok now :D
Rice crispy
