Gear Knob replacement, Thread size?
Postby m100sandra » Wed 11.12.2013, 09:42
Ime toying with the idea of replacing the gear knob, The Elans tucked away for winter :( so just wondering if the knob is threaded? If so, does anyone know the thread size?
Sandra
m100sandra
Re: Gear Knob replacement, Thread size?
Postby RayD » Wed 11.12.2013, 20:44
Postby m100sandra » Wed 11.12.2013, 20:55
Thanks for that Ray :)
m100sandra
Postby Elanlover » Tue 18.02.2014, 04:30
I think you'll find that a lot of aftermarket shift knobs come unthreaded and with a "universal" fit adaptor. They are without threads and have a rubber sleeve (they usually have several in the package of differing sizes) that slides over the threaded shifter shaft then tightens with the use of small allen screws. Every aftermarket shifter I've bought was like this.
Postby Jeemy » Tue 18.02.2014, 23:26
Anybody who has ever cut down their gear shaft for 'short shift', how much did you cut off?
T: 0800 084 3084
M: 07391 295 146
Jeemy
Postby Elanlover » Tue 18.02.2014, 23:32
I cut off all the threaded part. Probably about 1 inch or so.
Postby epipete » Tue 18.02.2014, 23:35
As you know from one of my earlier threads mine was cut down by a previous owner to 6 1/2". I was advised that "A stock gear lever is 7 3/8" so mine is about an inch missing!
I've never driven a standard shift so cannot complain but I am quite happy with 6 1/2 inches - size isn't everything!
Postby lotos » Tue 18.02.2014, 23:55
epipete wrote:I've never driven a standard shift so cannot complain but I am quite happy with 6 1/2 inches - size isn't everything!
6 1/2 inches is more than adequate.
lotos
Postby Elanlover » Wed 19.02.2014, 00:00
lotos wrote:6 1/2 inches is more than adequate.
Ok seriously. How many of you clicked on that link? Come on! Admit it!
Postby lotos » Wed 19.02.2014, 00:14
:cheers:
Back to the topic at hand - does cutting the lever down a bit improve shifting feel or make it more comfortable? I hadn't thought of doing that though I do have the short shift kit installed.
lotos
Postby steve matthews » Wed 19.02.2014, 00:52
It transforms the shifting. Ever drive a Miata :?:
Had mine surgically shortened 1.25" :lol:
Steve
steve matthews
Postby epipete » Wed 19.02.2014, 00:58
Was that by or too!!!!
Just straying off topic for a mo, in ref to the link, and, yes, I did click it, how do they know, who does this sort of research? I for one, outside this forum, have never been approached!
Postby m100sandra » Wed 19.02.2014, 07:29
The one that I ended up buying came with different thread inserts which fitted fine :-)
m100sandra
Postby lotos » Wed 19.02.2014, 17:33
What are people using to cut down their knob? Other then a Mohel..
Hacksaw? Recipricating saw? I've got one of those new-fangled oscillating "multi tools" I've been meaning to try out but I don't know if it can cut through metal like this.
lotos
Postby Elanlover » Wed 19.02.2014, 18:56
Dremel and cutoff wheel for me. A hacksaw would work though.
Postby Brit-Car-Nut » Wed 19.02.2014, 19:19
lotos wrote:What are people using to cut down their knob? Other then a Mohel..
The multi-tool will burn up a lot of blades trying to cut the shifter. I have a real Multi-Master and it doesn't cut metal well at all. Sheetrock is another story...
A cut-off wheel on a dremel or even on a decent regular drill will work as will a hacksaw (or reciprocating (hack)saw)
Postby lotos » Wed 19.02.2014, 20:03
Oh didn't think of a dremel, perfect thanks.
lotos
