Door card question
Door card question
Postby Gee21 » Tue 03.03.2015, 13:26
Hi,
Do you need to remove the door panel to remove the leather panel that matches the seats or are they supposed to pop off with the door panel still in place. Didn't want to force it.
Also does anyone know if the seat bases can be swapped passenger to driver and vice versa?
Many thanks in advance
Gee21
Re: Door card question
Postby Andy_J » Tue 03.03.2015, 14:22
There are screws behind the leather panel that hold the door card in place. The leather panel needs to be removed before you can remove the door card.
90H BRG SE 48,000 Miles
Andy_J
Postby Enright » Tue 03.03.2015, 15:46
Gee21 wrote:Hi,
Just the opposite actually - the leather panel has to come out to remove the door panel! But as for forcing it, it all depends on the method that whoever refitted it last time used to fix it. Chances are it's already been off as sticky window regulators aren't uncommon.
Gee21 wrote:Also does anyone know if the seat bases can be swapped passenger to driver and vice versa?
Yes they can. See here for some good pics of the disassembled parts: http://www.lotuselancentral.com/upgrade/hotseat.htm
Postby Gee21 » Tue 03.03.2015, 16:06
Great news many thanks for the replys. Yes the passenger side looks to be Welded on with glue. Just wasn't sure if there were screws behind.
Many thanks for the quick replys.
Gee21
