Tuga2112 wrote:I never done this thing of taking out the carpets to check underneath, not sure if what keeps me from doing it is the fear or not being able to put the carpets back right, or the fear of finding out what lies beneath....
any tips on that subject ?
). then i used a degreaser to start preparing the areas.epipete wrote:What's interesting here is that in Paul's photos the outrigger is sprayed a Gray colour and this, with what appears to be a seam, suggests that this has been subject to an earlier attempt at repair.
Nevertheless, it's not bad but need to be sorted soonest, Lightly rub it down, apply POR15 where you can see and Dimitrol where you can't. Stick a camera in the hole and have a look at the bracket. Then get rid of the old foam and replace with closed cell. Bingo, job done.
Tuga, the front is a known process and nothing to fear, it is the rears that worry me more!
Paul Alexander wrote:thanks for the comments guys. i've rubbed it all down today, and hoovered out all the mess (god, i hope my wife doesn't read this). then i used a degreaser to start preparing the areas.
Your wife need not fear the use of the Vacumn cleaner, it's when you use the dishwasher to prep all the greasy engine bits she'll need to be concerned! There are folks on here who have used their oven to cure painted items. Oh, and occasionally I think discretion with the monthly bank statements is called for
Tuga, don't be afraid of this particular job. this is the first time i've worked on a car since my old mark two escort back in '85. i was lucky though, the seat bolts came out very easily (no rust or seizing). then removed the seat belt anchor bolt, rear speaker box and carpet. took less than an hour.
petezipp wrote:Has anyone looked at holes in the floor to let water out?
petezipp wrote:Looks a good job . nice
Just a thought have you checked the drain holes under sill ( its in the manual )
Unless you have a fully watertight ( He He ) car or live in california I'm sure wet will get in the floor area.
would be doggy not to make matters worse,,
but old cars had bungs to drain out
peter The ex Triumph boy
